Installed my acs style pedals
My Ride: '10 Switzer "Ultimate Street Edition" GT-R
Just got through installing my acs style pedals....The dead pedal just screws into the plastic with 4 screws...Have to be careful you don't strip them...Screw head is pretty soft...Then take off the brake pedal pad....Line up the pedal and use a 7/64 drill bit to start a hole on the pedal...Remove the bake pedal cover and drill the 4 holes....You might have to ring them out alittle bit....Then put the 4 screws in, followed by the 4 washers and nuts on the back....I recommend using blue locktight so the nuts don't come loose...Then take the gas pedal off by removing the black cap and the allen bolt...Slide pedal off and line up the gas pedal...Drill 4 holes with the same 7/64 bit....Repeat the bolt,washer, and nut process...Then reinstall the gas pedal and your all done....Here is the out come...
Location: Milky Way, Earth, N. America, CA, San Jose, 95136, Latitude N 37� 16.837, Longitude W 121� 50.461
looks great! and nice DIY write-up!!
I got the pedals from Jbspeed....Here is the link for the pedals...http://forums.e60.net/index.php?showtopic=67192
Sharp!
