How to reset service light?
Old 03-12-2010, 05:45 AM
Troush's Avatar
I just took my 545 in a month ago before the certified warranty went out for a full check over and oil change but they didn't reset the service reminder. I now have 200 miles before my next service...does anybody know how to reset that or do I need to go to the dealer?
Thanks!
Old 03-12-2010, 06:45 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
1. Turn the power on (to II position), don't start the car.
2. Press the "trip" button on the instrument cluster until a triangle with an exclamation mark appears.
3. When the exclamation mark appears, release the button. Now you should see a sign of brake fluids. Keep pushing the button (down and up) until you see the mark indicating oil service. When the oil service mark appears, don't release the button but wait instead until the text says "reset" in the lower little screen on the cluster. Release the button and push again (keep pushed down) until you see the new date on the lower screen. Then release.
4. Turn off the power, then start the car and check the idrive. You're done.
.... IF I REMEMBER THIS RIGHT...
Anyway, you'll figure it out when you open the menu on the instrument cluster .
Oh! If the oil service in the idrive is already red, I'm not sure if this works. If it doesn't, I guess you need a dealer/or similar visit then to reset it...
- Antti -
BMW565
11-06-2017 06:03 PM
Sic Sticks
03-30-2015 01:17 PM
linxuan
E39 Discussion
03-22-2015 06:16 AM
das
04-23-2004 10:21 PM
jhalsey
01-25-2004 04:34 PM
Quick Reply: How to reset service light?
