How to replace E60 fog light bulbs?
Can someone tell me how to replace the fog light bulbs on the E60? I would like to replace the yellowish factory bulbs with the PIAA Extreme Whites. There are no instructions in the owner's manual on how to access the fog light assemblies, which are behind the black grill inserts on the fascia. I presume the grill inserts are removable, similar to the E39 setup. Perhaps someone can provide TIS documentation on what appears to be a simple operation.
Thank you.
Thank you.
Originally Posted by dba1t' date='Apr 8 2004, 08:21 PM
Can someone tell me how to replace the fog light bulbs on the E60?? I would like to replace the yellowish factory bulbs with the PIAA Extreme Whites.? There are no instructions in the owner's manual on how to access the fog light assemblies, which are behind the black grill inserts on the fascia.? I presume the grill inserts are removable, similar to the E39 setup.? Perhaps someone can provide TIS documentation on what appears to be a simple operation.
Thank you.
Thank you.
[snapback]6251[/snapback]
Email - philip@deenron.com
welcome aboard, xrsxj
! some of us did it and it took us less than 20 minutes
. our methods are a little different but basically is remove the panel from the bottom. it's a lot easier than remove the headlights
Banned
Here's the instructions I used:
http://forums.e60.net/index.php?showtopic=5912
I went with PIAA Xtreme White 4150K bulbs, which match the BMW xenons (which are 4200K) very well--here are pix:
http://forums.e60.net/index.php?showtopic=7232&st=0
!? some of us did it and it took us less than 20 minutes
.? our methods are a little different but basically is remove the panel from the bottom.? it's a lot easier than remove the headlights
.[snapback]165379[/snapback]
Administrator
My Ride: 530xi
Engine: N52
Tsoup
15
Dec 20, 2021 11:14 AM
tjackson9810
Apr 21, 2015 07:42 PM
Sai Paladugu
Mar 23, 2015 01:23 PM
