How to remove vents from front interior trim
My Ride: 04 525i CPO
How does one remove the vents from the front interior trim? Any info would be greatly appreciated.
Thanks in advnace.
Thanks in advnace.
Hi,
Very easy job to remove all trim on the E60 just take your time. You need to remove the main dash trim it just pops off.Be carefull when prizing it off. Easiest way is to open door and from the side of the trim insert flat blunt tool / screwdriver and slowly ease the first couple of clips off. When these pop the rest should come off in your hand. The vents then unclip from the trim as these will come off as one part at first. Couple of retaining clips and the vent is free of the trim. Good luck and take your time not to damage the trim!!!
Ian
P.s
Why you taking off the vents by the way??
Ian
P.s
Beemer
20
09-16-2004 12:36 PM
