How to remove dealer stickers from trunk lid
My Ride: Delivered 1/16/07 07 530i Silver Grey/Blk., ZSP, ZPP, ZCW, Logic 7, Step, Sirius
just picked up my new boy tuesday, anyone know the best way to remove the dealer stickers from the rear lid.....
My Ride: G30 M550i
Model Year: 2018
Usually the best way to do it is with a heat source like a heat gun or hair dryer. If you use a heat gun, be sure you don't bake the paint off of the car!
Once you heat the sticker, it should peel off fairly easily (don't rush the process). Once the sticker is off, you can use something like WD-40 to remove any glue residue that's left. After that, you can apply some wax or whatever you choose to protect the area where the solvent was used.
Having said all of that, what I usually do is ask the dealer to remove it (or better yet, I ask them not to put anything on at all...)
Hair dryer, dental floss and WD40 / white spirit / brush cleaner. Or ask your friendly dealer, as debadging is a no-cost option...
My Ride: G30 M550i
Model Year: 2018
You'll only need the dental floss if the dealer "sticker" is raised like the numbers that came from the factory (like 550i, etc.) Usually, dealers just do stickers, not the more expensive raised emblems.
My dealer does a license plate frame and as much as I love to promote them (I do promote them in many ways), I don't like the look of any license plate frame so I remove it or ask them not to put it on. As we mentioned, usually the dealers are very cooperative if you ask them to remove it...
My Ride: G30 M550i
Model Year: 2018
Originally Posted by dlevi67' post='381050' date='Jan 20 2007, 01:36 PM
My bad. And now I can't even edit the post!
(After something like an hour, you can no longer edit your posts...)
Originally Posted by nicdog' post='381087' date='Jan 20 2007, 03:59 PM
thanks, now if i could only figure out why my pics aren't uploading
My Ride: G30 M550i
Model Year: 2018
Originally Posted by cmansbimmer' post='381097' date='Jan 20 2007, 04:46 PM
the file size is probably too big.
http://forums.e60.net/index.php?showtopic=35724&hl=
