How to keep AE's bright all the time with NCS
My Ride: BMW E60
Model Year: 2016
Yes, you're missing particular files. Make note of what the files that are being communicated with when you try to read. Then search to see if you have those files. I had the same problem reading LMA module on LCI cars that had adaptive. I ended up getting the file from Blood and NoQuarter and has been good since.
Thanks for the info. I have adaptives on my LCI. My NCS Expert is complete from NoQuarter so I'm not sure, but I'm updating my DATEN files now (I'll try to copy over the files which are missing too). I'll check back with the result, might be useful for other LCI owners with adaptive headlights.
Engine: N54
We did a remote copy of the files PC-to-PC during a remote coding session. It worked for what we tried to do but still worth going through a fresh install of a good version.
Managed to make it work. Used the V40 daten files and added one missing file in EDIABAS\Ecu.
My findings:
If you change to wert_01, and read the ECU again after writing the MAN file, the new TRC is:
wert_01
wert_04
For some reason, the failsafe mechanism is adding wert_04 as a second line. I do not know whether the ECU only reads the last line, or a combination of lines. Can anyone confirm on how this works?
Anyway, after this change, you get:
- 12V inner angels in all modes, just like in with DRLs feature on in daylight, but now even in parking lights mode. Standard is reportedly 5V. You can now actually drive on parking lights with 12V inners AND eyebrows on. This is what DRL feature does but never with eyebrows at the same time from factory. Eyebrows are not that noticeable in daylight, but still pretty cool. Be careful here not to drain your battery if you use parking lights frequently when parking in the dark. Also it lights a dark street twice as more, which isn't always pleasing.
- Outer angels seem to be unaffected by this mod, I guess they always run at 12V but the stock bulb has lower output than the inner bulbs running on 12V.
- With main beams (xenons) on, 12V inner angels are noticeably brighter and more appealing. Looks great.
Please report your findings too, I'm curious to find out whether I'm right with mine.
My findings:
wert_01
wert_04
Tkx for test result
There's actually only 1 H8 bulb for both AE rings, the reason the inner brighter 'cuz it's closer to the bulb and I think what DRL originally designed.
Have you try to use wert_02 instead? It's what pre-LCI uses and pre-LCI don't have dimming ability.
My findings:
wert_01
wert_04
- 12V inner angels in all modes, just like in with DRLs feature on in daylight, but now even in parking lights mode. Standard is reportedly 5V. You can now actually drive on parking lights with 12V inners AND eyebrows on. This is what DRL feature does but never with eyebrows at the same time from factory. Eyebrows are not that noticeable in daylight, but still pretty cool. Be careful here not to drain your battery if you use parking lights frequently when parking in the dark. Also it lights the dark street twice as more, which isn't always pleasing.
My findings:
wert_01
wert_04
