How to find an intake leak
Old Jul 13, 2009 | 12:19 PM
BMWBen's Avatar
Looks like I've got a leak somewhere in the air intake on my 545i It's throwing fault codes and I can hear a high pitched whistle at idle coming from around the intake manifold.
Has anyone else with the v8 had this problem?
Any clever ideas on how to find it? The mechanic I took it too couldn't hear the whistle because it was too high pitched, so if I can locate it myself it would be a big bonus!
Old Jul 13, 2009 | 12:21 PM
Krozi's Avatar
Well, I would stop driving the car, because the intake leak could be after the air filter.... The intake tubing isn't that long so it shouldn't be THAT difficult to locate. Just look around a little
Old Jul 13, 2009 | 12:59 PM
BMWBen's Avatar
It's defo after the air filter - sounds like it's on the top of the engine block somewhere... Unfortunately I don't have much choice about not driving the car
Old Jul 13, 2009 | 01:20 PM
acuteperformance's Avatar
My Ride: 14 550i
spray bottle mixed with a bit of soap and start spraying your intake tubing. engine on of course
Old Jul 13, 2009 | 01:36 PM
rrnag30's Avatar
My Ride: 05' 545i
+1 on spray ----- soap water will bubble on the hole
find quickly if you have not other auto options for driving.
Old Jul 13, 2009 | 02:22 PM
Krozi's Avatar
+1 That's a really good idea
Old Jul 13, 2009 | 02:38 PM
pennetta's Avatar
That only works on something with higher pressure than where you are spraying from, not on a vacuum. You wont see bubbles because the soap will get sucked in.
Old Jul 13, 2009 | 02:46 PM
My Ride: 14 550i
good point but i believe you'll still be able to see it getting sucked in.
Old Jul 13, 2009 | 03:13 PM
pjinca's Avatar
Yeah, but you also run the risk of sucking soapy water into your engine - all it takes is a tablespoonful to ruin an engine.
Old Jul 13, 2009 | 03:19 PM
My Ride: 14 550i
another good point. how about use an air compressor and force some air in like about 2-5 psi and then check for bubbles.
