How to add an aftermarket sub/amp
Old Mar 2, 2008 | 04:05 PM
Tstoffer's Avatar
My Ride: My first BMW *** 2004 530i
[font="Trebuchet MS"]I have 2 12's and I was wondering if this would work the same way without having a mono amp? If so do you know what another sub speaker wire looks like.
Thanks.
Old Mar 2, 2008 | 10:34 PM
bruce_miranda's Avatar
Click the link in my signature to see how I installed 2 subs driven off a stereo amp. Ofcourse i made everything look stock but you'd get the idea.
Old Jun 1, 2008 | 11:37 PM
mancsfinest's Avatar
Hello 2 all . The time & effort put into writing these informative threads is well appreciated!!
Old Jun 3, 2008 | 11:17 AM
southgate's Avatar
nice instructions
Old Jan 11, 2009 | 03:38 PM
ey2001's Avatar
My Ride: 525i
so the white and purple wire is the remote right? i tapped into that wire but the amp is still on when the car is off.... anyone had this issue?
Old Jan 11, 2009 | 04:14 PM
ey2001's Avatar
My Ride: 525i
never mind.. its the right wire.. it turns off after 2 min and 30 seconds...
Old Jan 11, 2009 | 06:02 PM
kadafi39's Avatar
Hey acribb thanks for the write up, was extremely useful, one thing thats left me confused though is why you only ran one RCA from the line out converter, the LOC has 2 RCA outputs, so why not run both RCA'S directly to the amp? In your guide you ran one RCA from the LOC and then used a Y splitter to feed 2 RCA'S in to the amp not sure why you did this, but you obviously know what your doing. I ran both RCA's directly from the LOC and it worked, but there must be a reason why you chose to do it your way. Anyone know why you would do this?
Old Jan 18, 2009 | 11:04 AM
B M What's Avatar
My Ride: 2004 545i carbon black / dakota black / sport package / 19' beyern wheels - 285 rear with 15mm offset
So, does anyone know if this could be done to Logic7
Old Feb 24, 2009 | 02:16 PM
jchris's Avatar
Bump for Logic7 remote on/off wiring info. Is it the same white/purple wire?
Thanks!
Old Apr 19, 2009 | 01:41 PM
code37's Avatar
acribb is there anyway u can post pictures of the battery and the wiring of the battery? thanks
