High Beam Assist/FLA
It dont work like that, once the hardware is fitted your vehicle order will have to be changed and then the correct modules re-coded according to the new vehicle order, all this can be done with NCSexpert, takes a few seconds.
VA_longdistncelight just allows the fucntion to be stwiched on or off.
Hello guys,
I am quite interested in this too, I have mid 2007 LCI 535d with active cruise control and lane departure warning. I have adative xenon, idrive, pro nav, mp3 etc. Do you think I will need to get new centre rear view mirror with FLA camera? I already have one camera in the rear view mirror but thats for lane departure warning, won't that serve both purpose?
If I need to get FLA camera, is that a separate unit. Basically I don't want to replace full mirror with the lane departure camera just to add FLA, also not sure I can get a used unit which is FLA+LaneDeparture+autodim.
Please suggest.
Please suggest.
Hello guys,
Please suggest.
Please suggest.
Sorry for bringing the old thread back, but I have a question - is it possible to retrofit FLA to a E60 with LM1 light module. Are there any other requirements for modules or software version? I've already done this retrofit to a '06 car with LM2, but a friend of mine has '04 E60 and asked for FLA.
Thank you!
Thank you!
Should be possible because I had this on my car with LM1.
I have it also in my 2004 car with LM1.. Here are a really good EBA in German from http://www.e60fanatics.de/showthread.php?t=7548 made by trancy
My Ride: BMW e60 525Da LCI White, DPF out, Front grill black, Shadow line, license plate super bright led, interior white leds;
anyone did this? i have an e60 lci with dimming and rls, alarm and i have a mirror with fla, rls, dimming but without alarm, i read that these could put in new mirror from old mirror, on e90 a memeber did this.Anyone did this retrofit please help me!
My Ride: BMW M5
SA5AC High beam assist. Theres no FZD on the E60, FLA is the high beam assist module, it talks to the RLS (rain light sensor) and more than likely CAPPL (CCC-apps) and Chost (CCC-cpu), if you have a M-ask instead of CCC (business nav or no nav)
it`s slightly different, also I would imagine the CAS (cas access module) would need to know the FLA is there as well.
Confused?, complicated?.
Here is what I have done to my 2008 M5:
Installed correct mirror. Wired to K_CAN_SL and K_CAN_SH.
Changed the vehicle order to include $5AC in both the LMA and CAS.
Coded CCC_APP trace and changed VA_LONGDISTANCELIGHT to aktive.
I can see "high beam assist" in I-drive. But, the actual on/off of the high beam is still not working. What am I missing? Do I need to code the Kombi or something else?
I've done all of the above, I can see the FLA in INPA, I can diagnose it. The vin of the module is also changed. I've added $5AC and everything is coded accordingly. My KOMBI version is 9126642 lastly updated 09.11.2007. If I try to update it with DATE V50.2 it gives me the same number, thus I didn't proceed. The FLA sensor is working, the headlights are in auto mode, but the FLA is not working at all.
P.S. When I activate the FLA in the CAPPL and if I try to turn it ON it stays for 1-2 seconds ON and then automatically switches to OFF?
