HELP! Where's the clutch fluid reservoir on E60 545i? (Working
My Ride: 05 545i 6MT
Finished w/ CDV install but couldn't find the clutch fluid reservoir for bleeding the fluid.
I could only see the brake fluid reservoir.
Is the clutch the same w/ brake fluid reservoir?
HELP! and thanks!
David
HELP! and thanks!
David
Well, turned out that there's no separate clutch fluid reservoir.
It's COMBINED w/ the brake fluid reservoir.
I tried the classic method performing the bleed using press and release w/ a help of a friend but never got a good result after 15 mins of bleeding.
I ended up using pressure bleeder to get it done and oh boy it was fast to bleed the air bubble out!
Now my clutch feels gooooooooodddddddd
Originally Posted by mrfva' post='1004876' date='Sep 11 2009, 10:36 AM
Congrats David! I'm looking forward to my CDV delete, and clutch bleed ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
I'll give you back modded CDV you gave me.
I'm going to go ahead and remove the CDV all together and connect directly into the clutch slave
(my car has no more warranty left)
I own a 12/03 545i. From the instructions I received with the modified CDV I purchased, it sounded like my car had a dual compartment reservoir. I have not done the installation yet. I have a few questions for you since you successfully installed yours. How much of a pain is removing the underbody shrouding to get to the valve? How much did you have to remove? Did you just jack up the driver side of the car or did you have the use of a lift? Did you crimp the rubber hose to restrict flow or just let the fluid drain?
Thanks,
Bill
Thanks,
Bill
Removal of the underbody is very easy. It's just that there are lots of 8mm bolts and phillip head screws that hold the undertray but removal is very straight forward.
Remove the back section of tray (the one that covers the transmission and oil drain) and then remove the front section of the tray (the one that covers the engine).
I jacked on the jack point under the engine to raise the front, then I put jack stand under the jack point on the front L and R (under the front door). Just make sure you raise the car high enough to slide yourself under the car. You can also use rhino ramp to make things easier.
Make sure you get 11mm flare wrench. Well even w/ flare wrench, there may not be enough leverage to open the metal line, so I used vise grip instead![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
To restrict the flow, I used a trimmed golf T to stop the flow. I suggest NOT to let the fluid drain because if the reservoir is fully drained, then the master cylinder will have air in it) then you might have to bench bleed the master cylinder (a lot more work)
As far as bleeding, I also suggest you to get the pressure bleeder instead of pump the clutch pedal and release the bleeder valve (classic method). This saves a lot of time as you can just release the bleeder valve once then let the fluid flow until you see no more air bubble.
As dual compartment reservoir, I assume you have two master cylinder reservoir (one for clutch one for brake)?
IF this is the case then you would have to pressure bleed the clutch reservoir instead of the brake reservoir.
Mine is 2005 545 and I only have one reservoir (clutch and brake combine).
Good luck w/ the install. It's a straight forward install, it's just that the location of the CDV is fairly tight but it's reachable
My Ride: 2004 X5 4.4i Sport
2004 545i 6-Speed
I am obviously out of warranty, so I am not concerned about the lack of CDV. HOWEVER, does it work/fit to just remove the valve completely and bend the lines to make it fit? Is the end of the hydraulic line threaded to match the slave cylinder?
Just curious if anyone has done this....would like to save the $50 on the modified valve if I can....
Thanks!
2004 545i 6-Speed
Thanks!
Thanks!
Thanks
socale39
09-05-2023 08:30 AM
