Help PLEASE! Cant remove rear rotors..tried everything!!
My Ride: 04 545i
Bay Area, CA 04 545i sport package..
I am in the middle of a brake pad and rotor replacement. I have already replaced the front pads and rotors. The front rotors came off OK with some banging on the sides. However these DAMN rear rotors wont budge and now the sun has set....man I am frustrated.
The hand brake is off I have banged the crap out of the rotor and nothing.
What am I missing here? Are the emergency brake shoes some how stuck or something?
Some one PLEASE help.
THANKS!
THANKS!
My Ride: 545i Sport
Engine: N62
After removing hex bolt, use rubber mallet (Edit: and a length of 4x2 wood) and hit (wood resting at) 4 places on rotor (0, 180, 270, and 90 degree pos)
Continue hitting but don't use brute force, just enough to break it free
Good luck and use anti-seize compound when installing rotors, rims, or wheel spacers.
My Ride: G30 M550i
Model Year: 2018
In addition to the advice above, I assume you are working from the .pdf instructions I linked you to a few days ago...
(Don't bang the crap out of them -- you can do more damage than good!)
My Ride: 04 545i
After removing hex bolt, use rubber mallet and hit at 4 places on rotor (0, 180, 270, and 90 degree pos)
Continue hitting but don't use brute force, just enough to to break it free
...thanks for the anti-seize compound tip..will pick some up.
... I read some thing about adjusting the e. brake shoes through one of the lug holes....anyone heard of this?
Thanks guys.
My Ride: F10 M5
Model Year: 2013
I had trouble with mine as well, but I sprayed a little WD40 and got a big o hammer and popped right off. I had trouble with the rear driver side one.
My Ride: Numero Uno in Richmond Va 04 530 6 speed, jet black, black dakota leather, xenons, red rear reflectors, 545 front grill, cold weather package, premium package, staggered 19 inch BBS rxII/michelins, H&R coilovers and intergrated, R1 concept drilled an
Engine: 530i
Just replaced mine and make sure the emergency brake is off, the pads line the inside of the rotor and will hold on to them.
Once that is off spray the center with pcb wait a min or two then from the rear at the opening of the shield wack and then spin.
Dont go to crazy as you don't want to damage anything but a good dead blow hammer will do the trick
My Ride: 04 545i
What is PCB? some type of wd-40?
I am going to give it another go.
