HELP! PEDAL GOES ALL THE WAY AFTER BRAKE BLEED!
Old 06-13-2010, 09:04 PM
turboawd's Avatar
My Ride: 2006 BMW 550i
Originally Posted by motopokep
Turbo, which reservoir do you mean, the master cylinder or the pressure bleeder container? I alwayd had fluid in there. I'll re-bleed.
the reservoir above the master cylinder. as you're bleeding, look at the resorvoir(master cylinder) too make sure the fluid level doesnt get to low, otherwise air will enter your braking system, and then you'll have to start over.
Old 06-13-2010, 09:24 PM
Banned
John@Motorcepts's Avatar
My Ride: A Car
u probably bled it wrong. Try using the old fashion two person bleeding way. I bought the freakin self-bleeder tool and bled my gf's old car, an altima. I thought I bled it and once I drove away, I almost shit in my pants when I WANTED to brake. I had to pull on the ebrake and downshift. Then I did the two-person bleeding thing and works wonders. Try to see which brake line is also the longest. Bleed from the longest to the shortest.
Old 06-14-2010, 06:29 PM
motopokep's Avatar
My Ride: 530i
750 ml bottle of portwein $10
a friend to pump the break in exchange for a glass of port plus good company $3
frigging defective brake bleeder from BavAuto that lets air through $60
git R done, the 1st brake brake bleed job done all over again old schol style - priceless!!!!
DO NOT BUY THE CRAP FROM BAV AUTO, DO IT OLD SCHOOL.
the catch bottle helped though.
Old 06-14-2010, 06:47 PM
Banned
My Ride: A Car
knew it knew it!! OLD School is always the best!
Old 06-18-2010, 06:26 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
2 people method always work! I did my first brake caliper change last fall and used 2 people (my wife and I) method to bleed the brake. It worked very well.
Old 06-19-2010, 03:45 AM
constant's Avatar
I have the Bavarian Autosport brake bleeder, and it works fine. But...I have never used it by their "recommended" method. They recommend filling their unit with brake fluid, which I don't do. I always siphon out the old fluid from the reservoir (using an old turkey baster), then overfill the reservoir with fresh fluid. Then I simply use the BavAuto bleeder to pressurize the system for a 1-man bleeding operation. The one caveat to this method is you do have to monitor the reservoir fluid level, just as you do the old school way.
Constant
Old 06-19-2010, 06:06 PM
turboawd's Avatar
Constant
that sounds like the way to do it.
bestofthebest
03-28-2016 02:47 PM
msaudino
11-01-2015 03:52 PM
militantgrunt
09-10-2015 02:31 PM
Alan111
09-09-2015 07:42 AM
turbo_mustang12
09-02-2015 10:46 PM
Quick Reply: HELP! PEDAL GOES ALL THE WAY AFTER BRAKE BLEED!
