HELP!! My iDrive Turned BLUE
My Ride: G30 M550i
Model Year: 2018
I assume you've seen this thread that has some .pdf links dealing with the central information display (CID).
One .pdf of interest may be the first one in that post (the one from Sharp). On page five of that document, it goes over each pin on the input terminal for the screen. Maybe something happened to the wires that control the green and red signals?
Not sure -- just taking a stab at it. Maybe Dom can offer some suggestions...
Good luck!
Good luck!
But where are those pins and stuff? Anyways, I'm not going to bother to play around with it, I think its best if I bring it to the dealer. If they find out that I've been snooping behind the iDrive screen, I'm gonna have to pay for it. Any idea how much its gonna cost? Also, my central lock doesn't work anymore, my key's remote is not working as well but this maybe due to the fact that I drove in heavy rain yesterday.
My Ride: 2005 530i Individual, DVD Package, HUD, Bluetooth, Comfort Seats, SR, etc
damm i am sorry man...hope your guys at the dealer know some stuff.....i just pray that nothing like that happens to me cause my dealer here knows jack....
Wouldn't it be replaced under warranty? Why did yours break all of a sudden? But if the MASK is broken, audio and iDrive shouldn't work right? Mine works perfectly fine, only displays incorrectly. How about yours, Harry, did everything work fine like my car too?
My Ride: G30 M550i
Model Year: 2018
Hard to say exactly what's happening here. Clearly there are individual signal wires/circuits that handle blue, green, and red on the display panel. From the symptoms, it seems as if only the blue signal is working. Couple this with the fact that you were messing around with wires as you installed Dom's interface and it's a safe bet that something happened to the wiring.
As you said, if the system is working (except for the color issue) it's probably not a dead M-ASK unit but then again, I suppose anything is possible.
If you're sure there is no issue with wires (did you try jiggling the wiring behind the CID while it's powered up to see if you get any flashes of color?) then it's pretty obvious that you're going to have to have the dealer sort it out.
As far as warranty, it's common sense that if they can show that the failure is due to your "customization," then it's not likely to be covered. On the other hand, if it's not evident that you were messing around back there, then it might be covered...
Well I've covered my tracks real good. I mean unless the dealer goes through the wire inch by inch by inch, of course that would mean removing a lot of original BMW cloth tape originals and the ones I placed there to cover my tracks, they will never find what I did. Hopefully its as easy as changing the LCD out. If it requires changing of the M-ASK, it might cause problems, as they'll probably install new wires and take out the original wires to find that I tapped in a few places.
My Ride: BMW E60 9/04
BMW E46 / 3
Everything worked fine exept the colours went wrong. For exeample, under PDC the green bars went blue. That was disgusting.
The mechanics at the dealer had no idea, how this could happen. They spoke with munich and had to sent the MASK there. Then they got the right to replace it under warranty.
My friend had retrofit an E60 Interface at his bmw-dealer. Few days later his CID was complete black. He also got a new CCC.
My Ride: MY RIDE is DA real .-) HAMANN 5 aka BLACK MAMBA born on 16/06/2005/delivered on 05/08/2005 as following:
530dA (steptronic), Black II (JET), leather Dakota auburn black, mapple trim, head-up display, dynamic drive, active steering, adaptive xenon headlights (auto levelling) with headlight washers, alarm, comfort seats with massage function, advanced A/C, big compartment armrest, aux-in, MP3, Logic 7, Radio PRO, CD in-dash+cd changer, power rear sunshades, rear airbags, park distance control, auto dimming folding mirrors, smoking package, shiny shadow line (individual), fold down rear seats, ski bag, sport suspension, run flats on �116-style� rims (Good Year NCT5+), cup holders, debadged, fire extinguishers, additional permanent power outlet, BMW coat hanger, trunk release button (installed by Hobi), GPS tracking device and a big thx 2 Iceman.
Mods done:
� Authentic HAMANN FRONT APRON Including ellipsoid fog lights Item-No.: 10 060 110
� Authentic HAMANN REAR SPOILER Item-No.: 10 060 130,
� Authentic HAMANN HAMANN ALUMINIUM PEDALS For cars with manual gearbox Item-No.: 80 099 100 81,00 For cars with automatic transmission Item-No.: 80 099 120
� Authentic HAMANN FOOT REST In aluminium For left-hand drive vehicles Item No. : 80 099 122
� Authentic HAMANN HAND-BRAKE LEVER In aluminium For left- and right-hand drive cars Item No. : 80 099 216
� Authentic HAMANN Idrive of alu (sorry this is the only one in the World) but you can have it in carbon fiber ,
� Authentic HAMANN EXCLUSIVE FLOORMAT SET In black with HAMANN logo in silver For left-hand drive cars Item-No. : 80 060 120 For right-hand drive cars Item-No. : 80 060
� Authentic HAMANN COVER FOR OIL FILLER CAP In aluminium Item-No.: 80 099 117
� Authentic HAMANN SPORT REAR MUFFLER 4 TAILPIPES Sport rear muffler with four round stainless-steel tailpipes ( � 76mm ) Item-No.: 50 060 111
� Authentic HAMANN new add-on for M pack rear with diffusor for quad pipes -AVAILABLE NOW (http://forums.e60.net/index.php?act=ST&f=22&t=30630&st=0#entry332409)
� ///M steering wheel w Pegasus logo (this will be also changed to three spoke sports)
� ///M pack rear
� HAMANN ECU upgrade 265 HP 608 Nm.
most improtant:
�real and working like a charm forumsbuy real LED tails and PIAA 4700k fogs!!! for HAMANN full front apron you need H3
� CustomAngels, Angel Eyes Brighter than stocks 10X, WHITE & (REd for shows).
� Authentic HAMANN LIGHT-ALLOY WHEELS DESIGN EDITION RACE 20"
Ultra-light forged 3-pieced light-alloy wheel, Cross-spoke-design,Spider in black, titanium, screwing,polished flange
DIMENSIONS : 9.0 J x 20 FA Item No.: 91 207 315
10.5 J x 20 only RA Item No.: 91 207 625
Recommended 20" Complete Wheel Set DESIGN EDITION RACE I went with most aggressive Combination A.10 FA 9.0 J x 20 / RA 10.5 J x 20 with tires: FA 245/30 ZR 20 / RA 285/25 ZR 20
� Authentic HAMANN LOWERING KIT 4 progressive sport springs Lowering by approx. 40 mm FA, 20 mm RA Item-No.: 20 060 125
� Authentic HAMANN TIRE - PRESSURE CHECK SENSOR SYSTEM
� Authentic HAMANN SIDE SILLS Item-No.: 10 060 120
� Authentic HAMANN REAL CF ROOF SPOLIER Item-No.: 10 060 235
� Authentic HAMANN AIRBAG SPORT STEERING WHEEL 3-SPOKE Three-spoke design w their SMG paddles (For assembly O.E. airbag in exchange)
� Authentic HAMANN sports mirrors (all functions)
!!!!!!!!!!!!!!!!!!! and of course !!!!!!!!!!!!!!!!!
E60.net Clings
Still to do list;-):
� Our Hobi's camera system from : ww.switchchange.com).
� Individual leather interior (auburn+auburn alcantara)... and drive with sheer drivin' pleasure ... until 2009/2010 F10 comes or E60 possibly a 540d V8 diesel early in 2009 badly juiced!
I am sorry for you mates, I will let you know will have it normally end of Oct, but when a car is done by Hobi this never occur yeah he is not here has other businesses
Harry PM if you still need the help
