Help with 04 545i eject box install
Hello,
I am a new member that needs help with my CPT9000 eject box install. I am following mrbelks procedure. All went well until it came to plugging the eject box cable connector into the connector in the back of the console. The connector in the back of the console appears to have a protector or cap over the side where the eject box connector should plug in. I can not figure out how to remove the protector or cap? I must be missing something simple since mrbelk does not mention the step. I don't want to force it and take a chance of breaking the console connector. Any suggestions will be greatly appreciated.
Thanks,
Bill
Thanks,
Bill
My Ride: E60 530i
Engine: M54
Originally Posted by billeul' post='330280' date='Sep 3 2006, 08:21 AM
Hello,
Thanks,
Bill
Thanks,
Bill
I, too, had this problem to remove the cap when I install the V3 cradle. I took me a while to figure it out.
Hello,
Thanks for your reply. I see a lever on the connector shell attached to the ejector box cable. Are you saying that I should remove that shell? I don't see an obvious lever on the console connector. Are you saying there is one there also? Top, bottom or side?
Thanks again,
Bill
Thanks again,
Bill
Hello,
Thanks,
Bill
Thanks,
Bill
Hello,
Figured it out.
Thank you,
Bill
Figured it out.
Thank you,
Bill
Hello,
Thanks,
Bill
Thanks,
Bill
Hi Billeul!!
do you have a description/documentation of how to install CPT9000 in full details and pictures? please give me link... thanks thanks!~ Also, about the connector thing, can you also include the pictures of what you mean by those connectors... thanks again~~
DavaiLave
08-02-2022 02:16 AM
CertifiedOfficial
04-18-2015 12:11 AM
incoherent
04-15-2015 04:48 PM
