Golf Tee Mod / Trunk Panel Help
Old 08-31-2009, 08:41 AM
  #21
3Aims's Avatar
Originally Posted by DRANGED' post='993536' date='Aug 30 2009, 11:33 PM
I think the golf tee mod will do just the opposite on the E60, it will leave the valve closed all the time.
This is what I am trying to figure out. I just figured it was easier to pull the wire harness and test versus all of the clips/tees/zip ties.
Old 08-31-2009, 10:49 AM
  #22
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Alright. This has been discussed here years ago, see Link below.
This is found only on some model, 545i, 550, and 535i if I'm not mistaken.
Plug the line and the valve stays closed, meaning exhaust #2 is not working.
Golf Tee Mod / Trunk Panel Help-img_0510.jpg
What I did was chained and safety wired it in the full open position.
This mod really complimented my Twin Air Duct and Air filter Box mod (allowing more air in)
by having a more free flowing exhaust. The throatier sound is just an added bonus.
Just don't ask me for a before and after dyno. It drives better, believe me .
Link.
Old 08-31-2009, 11:03 AM
  #23
Gene's Avatar
^ Thanx Riz
Old 08-31-2009, 11:04 AM
  #24
545felix's Avatar
My Ride: 05 545/6
I had mine welded open for $20 before I ripped it out and put in the B&B (replaced by eisenmann later.)
FWIW- the valve on mine was squeaky as hell- and it opened up the second i touched the gas, below 1500 rpm. it's only there for noise control at idle. at least on the V8, it doesn't affect torque in the least bit. not sure on the 6 cyl cars.
Old 08-31-2009, 07:14 PM
  #25
Gene's Avatar
Originally Posted by 3Aims' post='993860' date='Aug 31 2009, 09:33 AM
You can do the golf tee mod by plugging the hose near the muffler with a tee/screw or by crimping it with a twist tie. You can also just unplug the wire that controls the flapper which is located right by the left rear tail light. The 335i has a small panel door that allows very easy access. Our 535i does not have the little panel door so you have to remove the left panel in the trunk to get to the wire harness. When I removed both twist screws the panel would still not come off, but I could pull it enough to see (but not unplug) the wire harness that controls the flapper. My question is when I remove the two twist screws, what else do I need to do to get the left trunk panel to pop off? It feels like something else is holding it in place but I can't find it.
Looks like T replied to you on your thread on n54tech..
Originally Posted by Terry @ BMS
Instead of doing that, remove the vacuum line and place a BB in it, and reinstall.
Old 08-31-2009, 09:28 PM
  #26
flyingpuck's Avatar
Originally Posted by sixcard' post='993612' date='Aug 31 2009, 12:36 AM
I can't wait to see this thread progress.
sixcard
As you wish!!
FIVE!!!!
Now THERE is progress!!
Old 09-01-2009, 11:12 AM
  #27
3Aims's Avatar
I'm wondering if the the BB would actually keep it closed all of the time as mentioned a few posts above. Our exhaust flapper seems to work opposite of the 335i dual exhaust from what I am seeing on several forums.
umichchris
12-07-2015 03:33 PM
ucsbwsr
08-17-2015 06:56 AM
ucsbwsr
23
08-07-2015 08:08 AM
e60_simr
07-29-2015 02:35 PM
Alfano
07-29-2015 05:23 AM
Quick Reply: Golf Tee Mod / Trunk Panel Help
