Frontal Brake Pad Noise (Squeeking)
Hey Everyone,
I have been having an issue with my front brake pads making this horrible noise when attempting to come to a complete stop. I went to the dealership and they said the noise is occurring due to the sensor on the drivers side grinding from the brake pads (apparently used to measure the amount of life left on the pads), I went ahead and changed them using ceramic brakes since they were previously semi-metallic. Even after changing the brakes myself, lubing them up, changing the sensor and putting the brakes back together the noise is still going strong. I'm thinking the issue is with the rooters, possibly need to change them? But the funny thing is, the computer on the car states that previously my brake pads had over 12,000 miles left on them. Would resurfacing the rooters be a good idea or complete change them?
Thank you so much! I'll appreciate any suggestions, going back to work on my beemer.
Hey Everyone,
is so funny...i was also today at the dealer for the same problem..i got exactly the same answer...weird
i have 30k on my car...and the mecanic sugest..to do for 600$ change the all 4 wheels brake pads...or( the perfect job he call it) the rotors and pads for all 4 wheels for 1400$...what i should do?
My Ride: 2006 BMW 550i
you should sand/scuff up the old rotors if you plan on re-using them.
Hey Everyone,
I had this same problem immediately after changing out my pads and rotors. I pulled my sensor out and re-positioned it and all went well. Good luck
BMW doesnt believe in Anti-seize, I had a l squeeling problem and it was the "anti rattle" clips. Pop those out add some anti-seize to the tips and put em back in, Now if you can take the caliper off pop the pads out and take a can of brake cleaner and lightly spray around rotor and pads. anti-seize anywhere there is metal on metal contact, then take some light grease and grease the sliding pins. Reassemble and it should nip most of your problems
PelicanParts.com
09-02-2015 07:44 AM
