Following in the Footsteps of ucsbwsr - DIY Installation VRSF 7" FMIC on an E60 535i
Old May 14, 2015 | 07:24 AM
chadillac2000's Avatar
Default Following in the Footsteps of ucsbwsr - DIY Installation VRSF 7" FMIC on an E60 535i
After reading the thread originally posted by ucsbwsr of how to to fit the 7" FMIC to our E60 N54 equipped cars, I was all in. I knew warmer months were ahead, I knew I was about to up the boost even more when going up to E65 fuel, and severe heat soak would be inevitable. Since I didn't want to deal with running meth, and I had access to E85, running E85 with a FMIC was exactly what I was looking for. The only problem is that most of the FMIC kits for the N54 are geared towards the 135i and 335i platforms. But it seemed like with a standard 135/335 kit, and a few miscellaneous couplers and pipes, we could make things work.
First off you'll need the VRSF 7" FMIC kit. I received the lower charge pipe upgrade, but DID NOT use it.
As far as extra components that you'll need, here are links to what I purchased extra. You could probably produce them yourself for much cheaper.
- a 15" long 2.5" 90 degree bend (http://store.max-redline.com/index.p...g-l-elbow.html)
- 4 more T-Bolt clamps (I got them from here - http://store.max-redline.com/index.p...r-exhaust.html)
- a 5" long 2.5" (http://store.max-redline.com/index.p...bo-5-long.html)
- a 45 degree 2.5" silicon elbow (http://store.max-redline.com/index.p...icon-hose.html)
- and a 30 degree 2.5" silicon elbow (Max-Redline didn't have these so I found them at SiliconIntakes.com - http://www.siliconeintakes.com/30-si...-30-p-196.html)
Once you've got all your parts together, now on to the actual installation:
NOTE: I've sinced revised this part of the installation in order to get the FMIC sitting perfectly straight and enhance the appearance of a bunch of small black zip ties. This required a decent amount of adjusting and the use of larger, 1/2" wide heavy-duty zip ties, so now I only have one on each side, but they're much beefier.
Old May 16, 2015 | 03:01 PM
Domrepkid's Avatar
My Ride: 2006 525i stick
Model Year: 525i
Nice write up pics are crystal clear
Old Jun 2, 2015 | 09:19 AM
aznfujikiddd's Avatar
My Ride: 535
Nice write up, that's 2 diys, front bumper removal, and fmic install.
Old Aug 29, 2015 | 09:33 AM
Kaane's Avatar
Banned
My Ride: 535i
EXCELLENT!
I will be doing the same next week.
Old Aug 29, 2015 | 11:55 PM
bmwmonkey's Avatar
My Ride: 535xi touring
Engine: N54
Very good write up! I don't like the idea of mounting with zip ties but everything else was great!
Old Sep 20, 2016 | 12:20 PM
sajadius's Avatar
My Ride: 09 535i Xdrive
Hey first off thank you for your post! Im attempting this install this week the pictures u posted dont show anymore anyway u can repost them or if its easier my email is sajadius7@gmail.com
Old Oct 6, 2016 | 08:27 PM
RCB's Avatar
RCB
My Ride: E61 535Xit
I have this setup on my E61 and didn't use zip ties. I made mounting plates that use the factory screw holes.
<a href="http://s1270.photobucket.com/user/neptunenow/media/1226524E-B985-4047-9278-077DE4543C38.jpg.html" target="_blank"><img src="http://i1270.photobucket.com/albums/jj604/neptunenow/1226524E-B985-4047-9278-077DE4543C38.jpg" border="0" alt=" photo 1226524E-B985-4047-9278-077DE4543C38.jpg"/></a>
<a href="http://s1270.photobucket.com/user/neptunenow/media/276ADA37-C79D-410D-BC4F-53693EDB6479.jpg.html" target="_blank"><img src="http://i1270.photobucket.com/albums/jj604/neptunenow/276ADA37-C79D-410D-BC4F-53693EDB6479.jpg" border="0" alt=" photo 276ADA37-C79D-410D-BC4F-53693EDB6479.jpg"/></a>
<a href="http://s1270.photobucket.com/user/neptunenow/media/0091F628-846B-44E7-9C72-F57A4BD31F41.jpg.html" target="_blank"><img src="http://i1270.photobucket.com/albums/jj604/neptunenow/0091F628-846B-44E7-9C72-F57A4BD31F41.jpg" border="0" alt=" photo 0091F628-846B-44E7-9C72-F57A4BD31F41.jpg"/></a>
Painted to give the stealth look and protect the aluminum.
<a href="http://s1270.photobucket.com/user/neptunenow/media/978E5C40-8FE1-443C-91B2-B74A5F804B1F_1.jpg.html" target="_blank"><img src="http://i1270.photobucket.com/albums/jj604/neptunenow/978E5C40-8FE1-443C-91B2-B74A5F804B1F_1.jpg" border="0" alt=" photo 978E5C40-8FE1-443C-91B2-B74A5F804B1F_1.jpg"/></a>
And here is how the pipes are joined and reduced to fit the outlets.
Old Apr 7, 2017 | 04:31 PM
gamblinfool's Avatar
My Ride: E61 535xi 6MT, '81 Scirocco Turbo Ragtop
Model Year: 2010
May I also request a set of the pictures? area53_at_gmail_com. Thanks in advance!
Jeff
chadillac2000
42
Sep 13, 2017 11:15 AM
Florida2002m3
Sep 1, 2015 11:09 AM
WolkuZ
Mar 9, 2015 11:19 PM
ZeZe
Oct 15, 2003 12:58 PM
