Fixed the gap between hood and M-Kit Bumper
Old 03-17-2008, 01:00 PM
MSportMatt's Avatar
My Ride: (2007) E60 - 520d Msport - Carbon Black,Black Dakota Leather, Carbon Fibre Trim, Business Nav, Bluetooth with telematics, Heated Seats, Parking Sensors Fr/Rr
Hi All,
My car recently had a new Bumper and Bonnet/ wings fitted after a front end collision
The Car came back last week and it looks perfect
However I now have a noticeably larger gap between the Bumper and Bonnet - as described above than before the bump. Everything else is lined up perfect - just about 5mm more of a gap than when new.
My car is an 07 MSport - does this mean that the Bodyshop have fitted incorrect Foam inserts during the repair?
Or should I try and complete Mods 1 & 2?
Any help appreciated.
Cheers, Matt
Old 03-17-2008, 01:18 PM
rodybmw's Avatar
Originally Posted by MSportMatt' post='546463' date='Mar 17 2008, 02:00 PM
Hi All,
Cheers, Matt
I would not try mods 1 & 2 since we now know that the correct foam piece fixes the gap problem. In your specific case I can think of two possibilities of why the gap is now present on your car. Either the wrong (non M-Tech) foams have been installed or they did not align all the body parts/ bonnet correctly when they did the repair. Either way it should be the body shop's responsibility to fix it...............so don't try the methods I described above.
Old 03-17-2008, 01:22 PM
MSportMatt's Avatar
Thanks Rody,
I think it is the Foams that will be wrong - everything else lines up perfect - Wings Bonnet etc.
Going back to the Bodyshop is a hassle and to be honest - I have the tech ability and time to sort this myself - hopefully!
So - can I remove the Bumper and do a quick check - by using the drawings above?
Roughly how much are the Foam inserts?
Regards, Matt
Old 03-17-2008, 01:46 PM
rodybmw's Avatar
Originally Posted by MSportMatt' post='546475' date='Mar 17 2008, 02:22 PM
Thanks Rody,
Regards, Matt
There are two foam pieces and they cost around $20-$30 each. However, I don't know if you can tell just by looking at them whether they are the regular or the M-Tech versions. Even if you were to read part numbers off of it most of the time those numbers don't correspond with the real BMW part numbers. You may want to first find out if a local dealer has the foam pieces in stock and then remove yours and take it down there to compare. I assume that it would be hard to tell the difference just by looking at one or the other, but if you can hold them next to each other you should be able to tell whether they are the same of different.
One other thing is that the M-Tech body pieces (bumpers, side skirts) have the letters "MP" on the back sides....which stand for "M Package".........so maybe the correct foam pieces for the M-Tech bumper would also have the letters "MP" on it ??? ...............not sure though.
Old 03-17-2008, 01:52 PM
BlaSTiWi's Avatar
Yes Rody, I got those two foam sittin' in the garage and they both have "MP" marking on the front side.
Old 03-17-2008, 01:53 PM
BlaSTiWi's Avatar
Yes Rody, I got those two foam sittin' in the garage and they do have "MP" marking on the front side.
Old 03-17-2008, 04:13 PM
rodybmw's Avatar
Thanks ......that's good to know.
Old 05-05-2008, 06:35 PM
vessval's Avatar
My Ride: * 2010 BMW 528i M Sport * 2010 BMW X5 M Blue * 2004 BMW 530i Sport, Silver Gray * 2004 BMW 530i Sport, Black Sapphire, Auburn Dakota Leather. * 2006 530I Monaco Blue / Grey, M-Tech Front and M5 rear bumper and side skirts. M5 lip spoiler. M5 166M wheels.
Hello,
Quad_m doesn't provide a correct M-tch foams. So cutting the foams to fit the brackets not always helps with the excessive gap
G
Originally Posted by coolguy' post='528719' date='Feb 8 2008, 12:41 AM
So, is the correct foam pieces included from quad_m ? I am having mine installed this weekend.. So I want to be sure this problem don't exist. Since I am paying a installer to do this Mtech install
If not, I guess I have to advise the installer to go with Washers route to fill the gap.. provided he can buy them from somewhere
Old 05-06-2008, 06:53 PM
juris335's Avatar
My Ride: BMW 535xi
Originally Posted by rodybmw' post='140318' date='Jun 17 2005, 05:41 AM
I finally fixed the gap that I had between the hood and the top of the M-Tech bumper in my car. I know there were a couple of people here who had the same problem and wanted to know how to fix it.
There are two metal brackets that are needed for mounting the M bumper to the bumper carrier. When I first did my installation I noticed that those brackets were being pushed down by the black styrofoam on the bumper carrier and thought about making cutouts in the foam so that the bottom of the brackets sit flush to the bottom of the foam, but then I decided to try it that way first. I did and noticed a bigger than usual gap above the bumper. Later on I noticed that on some of the installation pictures on this board it looked like some people had done the same thing that I was thinking of doing (makeing a cutout in the foam). I decided to try this but did not have time until today. It ended up getting rid of most of the extra gap, but there was still a bit more than I liked, so I tried to use some thick washers as spacers or shims under the mounting points at the top of the bumper. This helped get rid of the rest of the extra gap. I have directions and pics of both methods that I am posting below. I will call the foam cutout "Method 1" and post it here, and I will call the washer/spacer method "Method 2" and post it in a reply below. If anyone has this gap and wants to get rid of it I would suggest trying the second method first since it is MUCH easier and it works quite well. If that does not solve it completely then try Method 1 as well.
<span style='font-size:14pt;line-height:100%'>Method 1</span>
First of all notice how in the picture below the bracket is sitting below the big black foam on the bumper carrier. It does not even look that bad in the picture but once the bumper is put on it pushes down on the black foam which in turn pushes down on the bracket. This makes it very difficult to fit the bumper, and it is physically forced down, hence the big gap above the bmper. The foam needs to be cut out to a slightly larger dimension that the bracket so that the bracket sits inside the foam and the bottom of the bracket is flush with the bottom of the foam. You can see all these in the pictures below:
Would you know if the M-Kit BMW OEM is the same thing folks here refer to as the M-Tech Kit? Lastly, I ordered the OEM M-Kit but wonder if it will be installed on the East coast upon arrival or not until it gets tothe dealership? Thank you.
Old 03-13-2009, 02:40 PM
tbal's Avatar
My Ride: See sig :)
I just installed a m6 bumper on my 645ci, i seem to have fitment issue where fender meets the bumper as well, do you think thise could work for me?
Quick Reply: Fixed the gap between hood and M-Kit Bumper
