engine breather filter
Old 08-17-2009, 10:32 AM
  #41
Tesh's Avatar
My Ride: 535d M Sport
Originally Posted by AlwynMike' post='979149' date='Aug 17 2009, 09:30 AM
Tesh,
Just been to the $tealers for a replacement filter for my 530d. Of course, they tried to sell me a complete unit until I asked for just the filter. I noticed that on thier parts system, they didn't have the filter shown separately as it does on RealOEM, although the part number was available further down the list. Perhaps the 535 has the filter integral with the body.
I got the parts guy to show me the complete unit for the 530d, and it was just the filter, cover and gaskets in one bag (?37). The filter came with gaskets. Perhaps a trip to your local $tealer to have a look before you rip off the top of your engine!
Mike
Thanks Mike
I'll have a trip to the $tealers tomorrow to check
Paul
Old 08-18-2009, 12:29 PM
  #42
Tesh's Avatar
Been in to my local dealers today and the parts guy told me that its a different part no. to the 530d, it's also ?40+ compared to ?17
They have only ever had 3 in stock in the last 3 years' so seems to think it isn't a serviceable part.
He has ordered one in for me to have a look at.
Does anyone know if I need to change this?
Old 08-19-2009, 11:57 AM
  #43
bobsimes's Avatar
do not let the bmw stearlership rip you off you only need the filter which is available seperatly as i got mine from bmw bolton for 17 pounds uk you do not need the new filter housing as it is exactly the same as the one fitted to your car (530d 2004), all you need to do is clean the original housing, fit the new filter and replace thats it !!
if you want to get the 40 quid part then do so but i told you so when you realisse you have been ripped off!!
i have a 530d 2004 i bet the 535 525 are also the same part as it is the same engine.
simon
  #44
AlwynMike's Avatar
My Ride: Estoril Blue 440i GC
Model Year: 2017
Tesh,
For the 15 minutes it takes to get at the filter, it is worth having a look at what is fitted to your engine now - if its a "foam" type, and the replacement is a plastic vortex type, then I'd swop it. If your car is fitted with a vortex type already, then I'd put it back in and not bother replacing it.
Just because the $tealer hasn't sold any recently doesn't mean it isn't a problem. A couple of years ago no-one thought these were any trouble, but here we are discussing possible high bills if we don't replace, and the $tealers are now replacing it too as a matter of course. Now, if only they would admit that swirl flaps are a problem . . . . . .
Mike
Old 08-20-2009, 03:25 AM
  #45
Tesh's Avatar
Mike
I took your advice
When I got to the filter, I found that it was the hard plastic type, so cleaned it and popped it back in.
Job done and saved ?40........bonus
Tesh
Old 08-20-2009, 01:43 PM
  #46
AlwynMike's Avatar
Model Year: 2017
Excellent result Tesh,
The first time you do that job, it takes an age, but after the second or third time, it's just a breeze isn't it!
Mike
Old 08-23-2009, 06:20 AM
  #47
far1977's Avatar
Great PDF guide, I did mine this weekend - by the way if you ask the deal for an oil seperator he will only charge you ?17.90ish - the plastic casing is a seperate item.
I will post up the part number shortly
Old 08-30-2009, 12:41 PM
  #48
jas_r_1's Avatar
My Ride: 2006 520d - 19" 172s- Remapped - LCI taillights V6 cables - LCI xenon headlights - Denison 500 with BTA1500 - led interior lights - OEM led number plate lights Planned mods: Folding mirrors - Modmynav kit - High gloss shadowline trim -
Just checked my engine breather and glad it was the modified type. Also changed the air filter whilst at it. It took about four hours and this included a trip to the local hardware shop to get a torx 45 bit which I thought I had. Even then I could only get 3 out of 4 strut brace bolts out so had to work with the brace on. I'll pick up a better tool for next time and this should take half the time, if that.
Does anyone know if the breather needs to be changed or does it just need to be checked every service?
The PDF instructions were excellent and with this and another forum I have gained the confidence to work on my car. The only previous mechanical experience i've had is changing a car battery so the forums have helped me out alot. If anyone had said I'd be doing this type of work when I bought the car I would have thought you were crazy. So big thanks to all posting info and DIYs and hopefully i'll be able to post up a helpful DIY soon.
Old 12-01-2009, 08:33 AM
  #49
delwarulislam's Avatar
Doing this does it need any sort of resetting to the iDrive?
Old 12-01-2009, 12:03 PM
  #50
Macadee's Avatar
No, none at all.
Quick Reply: engine breather filter
