Egr bypass on e60
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
You should close both the small pipe and other larger side as the bypass i got has a block on both sides on the jublee side and small rubber pipe side
My Ride: M3 ZCP EX:2005 BMW 535D Sport, Estate, Steptronic, Carbon Black, Black Dakota leather, Head up Display, Profi Satnav, Bluetooth - only MULF module, Bi-xenon adaptive headlights, Sportseats, Cruise control, Active steeringMods: 19
Model Year: 2011
I tried today just to disable the small hose for the EGR valve, after 2 miles I had yellow light on the dashboard (kind of pump) it is the engine management and it said: Increased emission.
I don't know, maybe you have different engine management, but for me it does not work at all.
Il try and take one as i have bolted the engine cover back down try blocking both sides not just one
The best thing with it fitted the black smoke has gone
thesalboy
04-08-2015 09:13 AM
