E61 Blaupunkt satellite navigation fitment.
I would appreciate some assistance with wiring. I have a UK spec M Sport Touring 535d. It has bluetooth phone and a 6 CD changer but is otherwise standard spec. I have fitted a Blaupunkt DX-V Professional satellite navigation system. This was straightforward; the CD unit goes in the cavernous space where a spare wheel would be and the display sits on the dash. All is fine, except that the unit requires two signals from the car to work properly. I need to know where I can tap in the the loom to get these signals. The first should be easy; the reversing light. This should be available for a towbar installation; it's just which wire and where? The second is more complicated; it requires the speedo pulses. Now I know that there are two speedo outputs, one which is accurate and one to feed the display which is deliberately degraded to +2mph or so. It doesn't really matter which. Ideally, of course I would like the wire to be available in the back of the estate, but it's not a great problem running one forward in the sills if meed be. Again, which wire and where, please? My dealership has made helpful sounds but not actually given me the information.
Rowley (blueflightmedic)
:thumbsdown: Pure silence. Not really much use, this site, is it? To answer my own question after a lot of phone calls and some specialist help you need a CAN 01 bus to tap the bus and lift the signal off it.
Bank$hot530
07-12-2015 04:36 PM
