e60 Gearbox Software Update?
Old May 26, 2011 | 05:00 AM
frick's Avatar
Charger is MANDATORY.Wih Winkfpt software update for your gearbox take 5 to 15 minutes,its not a big deal if you update JUST your gearbox software.BIG attention to prerequisites.....
Regards!
Old May 30, 2011 | 08:47 AM
bmwfive's Avatar
Do I have to have progman installed to do this or can I just use the necessary files.
Also, what type of charger/power supply do you recommend?
Old Jun 3, 2011 | 01:35 PM
JasonH's Avatar
You actually need a power supply, not a charger (the voltage can vary with a charger). The power supply needs to be 13.9V and capable of supplying at least 40A continuously. Anything less and you take a risk of completely corrupting the module you are programming i.e. new gearbox ECU required.
Old Jun 4, 2011 | 12:25 AM
bmwfive's Avatar
To be honest, this will probably be the only time I do this so I doubt it will be worth buying a power supply. It might be cheaper (and safer) to just get it done at the dealer/specialist.
andrek
Apr 4, 2015 08:47 AM
andrek
Mar 26, 2015 08:00 AM
mikekilpatrick
Mar 6, 2015 05:40 AM
Farbton
Nov 15, 2003 06:54 PM
ZeZe
Oct 15, 2003 12:58 PM
