e60 climate control from e70 retrofit-- Help Needed!
Old Jan 18, 2016 | 05:01 AM
rb81's Avatar
My Ride: e60 Lci
Default e60 climate control from e70 retrofit-- Help Needed!
Hi All, iam new here, but have been reading it for quite sometime now.
So, the idea is to fit climate control from e70 X5 to our e60 , i think 5 series owners got mistreated due to the fact that rest of BMW line up got proper climate controls with digital display and lets admit it will look much nicer then 3 lifeless knobs.
Retrofitted basic AC to High following Blood's manual - https://5series.net/forums/diy-do-yo...ev-3-a-117450/
So , i bought e70 climate control with all connectors, didnt come across fitting it yet as still in progress of searching.
There is a pinout on WDS , but the question to all BMW gurus is , is it gonna work when fitted and coded?
As per manual for e70 IHKA not all pins will be used: only 2 and 3
Old Jan 18, 2016 | 05:06 AM
rb81's Avatar
My Ride: e60 Lci
By the way the e70 ac control is wider then e60's , but the actual space for it is perfect, so i pressume it can be fitted with small adjustments to the bezel
Old May 3, 2016 | 04:55 AM
ericono's Avatar
My Ride: 1985 M635, 2010 e61
Model Year: 1985
Did anything happen with this? Curious to see installed pics and here a report out if it did.
Thanks,
Eric
JonathonK
Jun 8, 2015 11:56 AM
trev0006
F10 Discussion
Jun 4, 2015 07:33 AM
nathanhun
May 8, 2015 04:04 AM
ZeZe
Oct 15, 2003 12:58 PM
das
Jun 17, 2003 06:55 PM
