DIY: Shocks install
Old 09-17-2009, 11:39 PM
  #31
Brit_in_NJ's Avatar
My Ride: '05 545 Titanium Silver, Black Leather - Nav, Logic 7, Cold weather. Mods: Carbon filter removed. M5 iDrive knob. Umnitza license plate LEDs. MP3 40% 3M tint ACS Anti-Roll(sway) bars RPI Scoop G-tech Pro RR CF Roundels CF Wheel caps
I only did the rear driver side shock install. The passenger side will be harder according to Allen (e60_lab_rat) because of the fuel lines.
I guess I'll find out tomorrow.
Well done, Can't wait till the final installment!
Old 09-19-2009, 12:53 AM
  #32
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Rear Shock (Right side) Install
Allen was right! There is this plastic piping(Vent Pipe) from the gas filler.
DIY: Shocks install-2009_0919_22151aa.jpg
1. Chock the front wheel and raise the rear wheel off the ground. Remove the wheels. I placed another 2Ton jack under the differential housing forward of the cooling fins for added safety.
DIY: Shocks install-2009_0918_15551aa.jpg
2. Remove the lower shock mounting bolt(18mm).
DIY: Shocks install-2009_0918_15561aa.jpg
3. Access the upper shock mount by removing the side trunk trim panels. Remove the 3 (13mm) upper shock mount nuts.
4. Remove Wheel well liner plastic nut and a few screws. The secret is being able to pull the liner out of the way for the shock to come out.
Screw the wheel bolts so you can step on them and push down with all your body weight (I'm not kidding)
5. Continue with instruction 5 from Post #30.
There it is folks. The ride is much more enjoyable, the way the ultimate driving machine should be .
Old 09-19-2009, 02:04 AM
  #33
Brit_in_NJ's Avatar
Great DIY! Any more detailed feedback on how the ride compares on the m-sport over sport setup?
Old 09-19-2009, 08:51 AM
  #34
e6t.lab.rat's Avatar
Great job on this DIY and the R&R on the M sport shocks and springs (love your sig - now the diff? ) . Don't it feel great accomplishing this? Well, maybe mentally but physically it'll take a couple of days to recoup right?! haha
Now sit back, (floor it!) and enjoy your ride brotha.
Congrats Joe!
Old 09-19-2009, 07:06 PM
  #35
krusir's Avatar
My Ride: 2009 535xi, short shifter, no CDV
I am glad that our e60 can remove top rear shock mount from trunk. I recall hours I spend to figure out how to remove the rear seat and back dash cover, then speaker to get it in my previous e39.
2 to 3 years later after mine hit 50K miles, I might do the job as well in my xi. I hope by that time, we will have more selection for xi folks.
Originally Posted by Rizbel' post='1010835' date='Sep 18 2009, 12:10 AM
Rear Shocks Install
Attachment 90421
Attachment 90422
4. Remove liner plastic nut.
Attachment 90423
Pull the strut out of the liner and out of the wheel well.
Attachment 90425
5. Using a spring compressor, compress the spring and remove the upper shock-to-mount nut (10) and disassemble the Spring pads(upper 6 and lower 3), upper mount plate (9), mount(7), lower mount washer(5), compression absorber and dust tube(4) from the shock.
Attachment 90424
6. Assemble all of the parts from step 5 onto the new shock.
7. Install the shock assembly in the reverse procedure from removal. Install the trunk trim panels.
Install the wheels and lower the vehicle.
Note:
Old 09-25-2009, 07:35 AM
  #36
suthurnbimmur's Avatar
My Ride: 2004 BMW 545i
GREAT write up and thanks again!! Do you have to torque the bolts when putting back on? thanks.
Old 09-25-2009, 08:29 AM
  #37
pjinca's Avatar
This is a great write up, you are "the Man" - great job and even better detail. Much respect bro.
Old 09-25-2009, 03:26 PM
  #38
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Front shock nut to piston rod 64 Nm (47 Lb-Ft)
Front upper strut mount nuts 34 Nm (25 Lb-Ft)
Front 16 mm bolt 59 Nm (44 Lb-Ft)
Front 18 mm nut 65 Nm (48 Lb-Ft)
Rear Shock to Wheel carrier mounting bolt 165 Nm (122 Lb-Ft)
Rear upper shock mount nuts 28 Nm (21 Lb-Ft)
Rear shock nut to piston rod 27 Nm (20 Lb-Ft)
I'll re-torque again after few hundred miles.
Old 10-22-2009, 10:58 AM
  #39
545felix's Avatar
My Ride: 05 545/6
any difference in ride height?
Old 10-22-2009, 11:26 AM
  #40
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Same as regular sport suspension. I think the M Sport suspension has been recalibrated, don't know what that means.
Quick Reply: DIY: Shocks install
