DIY for SA430 mirrors
#71
I have a 04 525 with option SA430 but the only thing I can say for sure that is active is the pass side auto dipping feature when shifting into reverse, I have used ncs to activate folding mirrors but wither the code isn't saving to the mod or I sm doing something wrong when it comes to the coding?
#72
My Ride: E60 530d
Hi I have a 06 non memory seats push button start I had four wires on mine originally but got pre LCI folding mirrors with looms and modules then found out they was no good so I got some newer ones with three wires and looms I believe off a 07_08 ish .I have changed them all and coded them in with NCS expert the new looms also have the three wires. The drivers mirror works out wrong with the button as as up comes in in goes down down goes out out goes up or something like that. The passenger side doesn't work at all. And the mirror does not move in The windows work. Is there something else I need to do or rewire. Any help would
Be great thanks in advance
#73
My Ride: E60 530d
I have retrofitted SA430 mirrors today.
It was Plug 'n' Play with some coding. (Half an hour job)
So, anyone who has post 9/2005 vehicle equipped with memory package, and electrochrome interior mirror can simply swap the mirrors, do some coding (Adding $430 to VO in CAS and LMA and then enable ABKLAPPEN function in KGM) and have their awesome power folding mirrors!!
#74
My Ride: E60 530d
#75
My Ride: E60 530d
Hi I have a 06 non memory seats push button start I had four wires on mine originally but got pre LCI folding mirrors with looms and modules then found out they was no good so I got some newer ones with three wires and looms I believe off a 07_08 ish .I have changed them all and coded them in with NCS expert the new looms also have the three wires. The drivers mirror works out wrong with the button as as up comes in in goes down down goes out out goes up or something like that. The passenger side doesn't work at all. And the mirror does not move in The windows work. Is there something else I need to do or rewire. A 4ny help would
#76
BEIKLAPPEN_B_KONFORTSCHL (KGM)
ASP_BEIKLAPPEN (KGM)
ASP_LIN_SPIEGEL (KGM)
KOMFORTOEFFNUNG (CAS)
KOMFORTOEFFNUNG_FB (CAS)
KOMFORTSCLIESSUNG (CAS)
the new mirrors get moved from the switch horizontally, vertically from door switch and passenger side tilt in reverse.
No folding at all with keyfob. I can close door and windows by keeping pressed the close button on the keyfob but no mirror folding.
Any help on this would be really appreciated
