DIY - Fuel Filter/Sending Unit Swap
Old 03-02-2012, 12:36 AM
AchtungE60's Avatar
My Ride: E60 530i
Originally Posted by jgt
Great DIY!
What benefits have you noticed? MPG improvement? Smoother idle? Better acceleration?
Both. Just got back from a 600 mile trip got an avg of 26.4 mpg and i pretty much kept it at 90-100mph and occasionally at the 70mph speed limit.
Old 03-02-2012, 09:34 PM
ck-e60's Avatar
My Ride: 545i - GONE
I freaking love this forum, just purchased my fuel filter and I'll be changing on my 545 tomorrow. Wonder how dirty mine is, I'm at 127,000 miles.
Old 03-02-2012, 09:46 PM
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
The reason why I still read the forum . 116K miles and I'm sure a new fuel filter is needed. Thanks guys!
Old 03-04-2012, 09:49 PM
ck-e60's Avatar
Just replaced mine, some fuel seeped out of the main line and it was DARK black, gross. Make sure you tighten the collar nut real well, I had a leak in mine because I didn't tighten it all the way with the hammer/screwdriver. Better to do this job when your tank isn't full of gas.
Old 03-04-2012, 10:59 PM
healthservices's Avatar
Yes if you can help it make sure you have a half tank or less as the cap is not at the highest point. I had to siphon my tank when my pump went bad. I just happen to have a full tank of gas.
An if I remember correctly there was no seal so make sure to order one when you order the filter.
Old 03-06-2012, 03:44 PM
AchtungE60's Avatar
My Ride: E60 530i
Hahaha. Sorry if I left out the part. Bro I just copied and pasted someone's directions and elaborated and added my own pics since his wasn't really an official tutorial. I had about 8 mi. left until empty.... i mean what the hell, if you do run out of fuel you should always replace the fuel filter because you'll be sucking black shit fumes anyway. lol.
And it was hard to take the nut off so that means PUT IT ON HARD lol.
Yes there is no seal that comes with the unit...mine anyway. I didn't replace that I used my original seal, after tightening nut it wasn't necessary. I would have if it came with one but it didn't so I didn't and it really wasn't necessary either.
I did forget to add that I had two gallons of 93 octane on standby. Filled it up, drove to the gas station, added some good Fuel conditioner/cleaner and then filled her up with 93. Good to go!
Old 03-16-2012, 02:32 PM
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
I'm going to be busy soon .
DIY - Fuel Filter/Sending Unit Swap-img_08521.jpg
Old 03-20-2012, 08:18 AM
zamestytel's Avatar
My Ride: 2011 535 Xi
Great job sir!
Old 03-23-2012, 06:58 AM
the awakening's Avatar
My Ride: 2004 525i 1997 318ti - Sold 1990 535i - Gone
I finally got around to doing this. It didn't completely stop my rpm surging issue (which has been diagnosed as a bad trans) but it sure helped with making acceleration smoother. My car has 145k on the clock and definitely needed it. I attached a picture of the gas that poured out of the old filter. Nasty...
Attached Thumbnails DIY - Fuel Filter/Sending Unit Swap-2012-03-10-15.55.50-hdr.jpg
Old 03-27-2012, 04:43 PM
AchtungE60's Avatar
My Ride: E60 530i
That is some nasty gas. I think mine looked like that too but since I didn't put it in a container I can't show. thanks.
Quick Reply: DIY - Fuel Filter/Sending Unit Swap
