DIY: E60 Sport Automatic Retrofit Redux
#72
My Ride: 530e Alpine White
Model Year: 2017
Take a look at the link for instruction to change VO. http://www.docstoc.com/docs/15087350...icle-Order-BMW. You need to remove $205 and add $2TB to KOMBI. You do not need to code the entire car.
#73
Model Year: 2017
No. This is for LCI models, with electronic gear selector switch. Try search for pre-LCI there is also a procedure for it.
Update link
https://5series.net/forums/topic/820..._1#entry954193
Update link
#74
Model Year: 2017
I have just replaced the steering from a workshop. The steering bolt was too tight, could not get it off with my tools. I was hoping that I could do the wiring without taking off the steering. Any ideas? I see I can pry off the front cover and pry the bottom cover partially, but, could not get it completely out, does not look like it is stuck due to front cover. Also once I unscrewed the screw on the bottom cover, I could not put it back on. Please some advice, I am planning to finish off the wiring tomorrow.
#75
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
Hi guys i have the following parts for sale if any one is looking to do a complete retrofit
i have listed the part numbers and prices these are from Bmw im looking for £380 for the complete kit the kit is good condition £380
The complete kit is £553.73 from BMW
51166985887
Black Leather Sat Gear Shifter Surround £73
61319208272
Selector Gear Handle £144
61319142869
Sport Switch £59.21
61319212220
Shift Box, Gear Selection Ecu £277.52
51166985887
61319208272
61319142869
Sport Switch £59.21
61319212220
#77
Model Year: 2017
I have not done it myself as I have a 525i for which there is no firmware with sat support, but, during my investigation I found that it takes around 10min to complete the flash. You should preferably hookup to a stable power supply or atleast a running car. As the voltage should be steady while flash otherwise it might corrupt/brick the controller.
#78
My Ride: 550i
Model Year: 2011
LMA and CAS have 2TB programmed and Kombi as programmed but SPORT does not show up in cluster when pressed. No rev matching or throttle blips. Just getting stiff steering when SPORT button is pressed.
#79
Model Year: 2017
AFAIK in order to get rev matching and throttle blips you need to flash egs with 2TB firmware. And the sport in cluster should work as soon as you do expert mode coding 2tb in kombi with empty man file. while doing the coding in kombi ensure that 205 is removed from fa.
#80
My Ride: 550i
Model Year: 2011
But a lot of the posts suggest NOT to program using a blank .man file.
Also, how do I make sure that the KOMBI knows about 2TB? Both CAS and LMA show 2TB in Vehicle Order already.
