DIY: E60 Sport Automatic Retrofit Redux
Old 10-11-2011, 09:26 AM
  #21
NoQuarter's Avatar
Engine: N54
Originally Posted by bert69
Question : is it also necessary to edit the FDC -Dynamic Driving Controlfunction- by coding SAT in a LCI to have full function of the sportbutton ?
Doesn't sound familiar to me. I posted what I thought was all the needed info. I can check closer to see if something was done there. Where is FDC and what does it do? I may not even have it because mine is an xi.
Old 10-12-2011, 05:43 AM
  #22
bert69's Avatar
FDC is the funktion of the sportbutton ... read here :
http://tis.spaghetticoder.org/s/view.pl?1/08/78/41
i only feel a heavier steering after coding but nothing else. the heavier steering was without coding also possible by pushing the button. so I thought that maybe necessary the coding fdc (sport button) to. for the features what is still missing.
Old 04-09-2012, 06:17 AM
  #23
murdock's Avatar
OK so I'm comfident enough to consider doing this by myself. I can see where the parts are listed online but I can't find where to purchase these parts online. My dealership has it buts its very costly. More info pls. 08 Alpine white 535i
Old 04-09-2012, 05:37 PM
  #24
NoQuarter's Avatar
Engine: N54
Try this dealer. You can order online and free shipping for over $200. The prices always seem to be better than others.
Ask for Fred the parts manager if you call - he is great to work with.
http://www.basneypartsonline.com/par...?siteid=216095
Old 05-15-2012, 08:54 PM
  #25
terraphantm's Avatar
My Ride: 535
One major aspect this retrofit is missing is reprogramming the actual transmission module. The sports auto and standard auto have different software.
Using WinKFP, I flashed my standard auto (in a 535xi) to the sports auto software (in the case of the 535i, it's 7601458 as of Ista/P v41.. may have changed in newer releases). I had to clear a few errors in the DSC, EGS ,and DME, but after that the car had no complaints.
The transmission still works, and it feels like it shifts faster, particularlly in S and M modes. It's also a lot more aggressive about downshifting in S mode. I did *not* change my VO, nor did I recode my KOMBI (partly because $2TB was never an available option for the xi models). However, my KOMBI is behaving differently now; when I'm in S mode, it displays the gear the car is in instead of just simply showing "DS" - I will probably try adding $2TB and see if my KOMBI accepts it.
I have not retrofitted the sports shifter (yet), so I have not been able to test the actual sport button. But even without it, it's a pretty nice upgrade. And it does seem to work properly on the xi despite it never being available officially on the RWD models.
EDIT: Well the car did accept the $2TB VO without complaint, and I was able to recode the KOMBI without issue. The FSW_PSW does show changes, but I cannot say I actually notice anything different with the recoded KOMBI.
Old 05-16-2012, 05:17 PM
  #26
NoQuarter's Avatar
Engine: N54
Great update. Been planning on getting back to mine after reading some more about the software versions. Always new there was an improvement but I was never convinced it was working fully as intended.
Old 05-27-2012, 12:12 PM
  #27
aal2000's Avatar
Any update?
I am very interested
Thanks
Old 05-27-2012, 05:38 PM
  #28
NoQuarter's Avatar
Engine: N54
The only GKE files I have that are similar are in the Data folder GKE215 and they skip 7601458 - I have A7601457 and A7601459. Your thoughts on this?
How did you go about clearing errors in the other modules?
Edit:
I just looked at what I was currently running and it is at version 7601460 (file date 3/11/2009 (Nov 3, 2009) ) which I don't have in my list of files so this must have already been there or my service center did it during another software update process. I do have 7601461 in my list so I will see if that is a suggested update.
Old 05-27-2012, 05:55 PM
  #29
AchtungE60's Avatar
My Ride: E60 530i
If you need programming send me a PM and we can discuss.
Are you sure you got all the files? Complete files will be around 7gb of data for E60
Old 05-27-2012, 07:40 PM
  #30
NoQuarter's Avatar
Engine: N54
Not sure if you noticed my edited post - turns out I am running 7601460 already. Anyway to know is this just a newer version of the 7601458 SAT?
Quick Reply: DIY: E60 Sport Automatic Retrofit Redux
