Disable e60 Seatbelt Gong.
My Ride: 2005 545i Sports Package
Hello,
I have an 05 545i and use ncs expert for coding. I was wondering if anyone know the code to disable the seatbelt gong. I've searched the forum but can't find one. I'm aware that it will still gong, but only twice.
Thank you.
Thank you.
My Ride: 2014 535 Alpine White
Mine is disabled and it doesnt gong at all. I just get the red seltbelt sign on my dash when the seatbelt is not on. I had someone do some coding for me.
you can buy a seatbelt plugin thing (it just slides in your seatbelt receptacle) or have it coded out.
My Ride: 2010 535i M-Sport
I wish I knew the answer for you (still trying to learn how to code anything) but over at bmwcoding [dot] com they have a very nice list of coding options for our E60's. Hope that helps you!
Curious as to why someone would want to disable this safety feature? I can see if you get in the car and are just pulling up a little and then this annoying noise gongs, but it's supposed to be annoying, this way people will wear it. I've seen the plug in's tricks the system to thinking the belt is connected. Maybe try one of those. Keep in mind, with out your belt connected it can take hardly anything to cause the airbag to deploy, just a small bump/fender bender could possibly do it. I've seen it before. The system knows that you are not secured so it deploys the AB sooner and with less impact. Then you end up with a big mess when it deploys. My luck I would tell someone how to do it and the next day they would be in a horrific crash where the seatbelt would have made a big difference.
This is a controversial subject, so I'll just say that the gong is referred to as the Seat Belt Reminder. There are two settings, one for the Driver and one for the Passenger. HTH.
My Ride: 04 545i 6 speed
92 535i 5 speed
88 325i auto
[Acoustic seat belt warning disable]
Note: The effect on the release behavior of the air bag is unknown.
Control unit: ABG
SBR_BEIFAHRER_ACSM
active -> nicht_aktiv
SBR_FAHRER_ACSM
or a vehicle, contracting with the value:
+ OI11 for the driver
+ OI12 for the passenger
and
to 03/2004:
Control unit: COMBINATION
SBR_BEIFAHRER
nicht_aktiv
SBR_FAHRER
nicht_aktiv
from 03/2004:
Control unit: SGM
SBR_BEIFAHRER_SGM
nicht_aktiv
SBR_FAHRER_SGM
nicht_aktiv
09/2005:
Control unit: ACSM
SBR_BEIFAHRER_ACSM
nicht_aktiv
SBR_FAHRER_ACSM
nicht_aktiv
Control unit: ABG
SBR_BEIFAHRER_ACSM
SBR_FAHRER_ACSM
and
to 03/2004:
SBR_BEIFAHRER
nicht_aktiv
SBR_FAHRER
nicht_aktiv
from 03/2004:
Control unit: SGM
SBR_BEIFAHRER_SGM
nicht_aktiv
SBR_FAHRER_SGM
nicht_aktiv
09/2005:
Control unit: ACSM
SBR_BEIFAHRER_ACSM
nicht_aktiv
SBR_FAHRER_ACSM
nicht_aktiv
My Ride: 523 Touring 2006, 328 Coupé 1999
Initially my (very old) sp-daten files were too backlevel and couldn't handle it. Sorted it out by a sp-daten upgrade (to v41).
