CPT9000 installation technical details
Old Feb 26, 2005 | 11:47 AM
  #31
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Originally Posted by Newdetour' date='Feb 25 2005, 04:04 PM
Can someone add info on how to remove the arm rest or provide a hint of how to route the eject box cable through the "inaccessable" path at the back of the box?
[snapback]94395[/snapback]
I'm not sure I understand your question. The instructions posted pretty much cover everything you need to install the eject box.
The following document (already posted in post #6 above) is the only thing I can think of that might answer the question:
Attachment 136546
If that doesn't answer it, can you clarify your question?
Old Mar 16, 2006 | 05:29 PM
  #32
ATLESixty's Avatar
My Ride: Silver Grey Metallic 545i, Logic 7, Comfort Seats with Black Dakota Leather, Sirius Satellite Radio, Euro Reflectors, Aux Input Build Date 9/03
Attachment 136546
I am having the same problem. Look at page 3 of the PDF in post #6 and it says that "the driver's armrest and plastic trim" must be removed to route harness. I sure the hell can't figure out how to do it and neither could Mr. Belk in his early DIY install of the ejectbox
Old Mar 16, 2006 | 06:05 PM
  #33
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Maybe this will help?
replacing_center_armrest.pdf
Old Mar 17, 2006 | 03:47 AM
  #34
ATLESixty's Avatar
Attachment 16659
Check! Now how about that plastic trim? (It is the piece that the armrest is connected to.)
Old Mar 17, 2006 | 04:51 AM
  #35
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
I'm not sure this is it but it's pretty much all I can find with the time I have at the moment....
replacing_center_armrest_adjustment_unit.pdf
Old Mar 17, 2006 | 05:28 AM
  #36
ATLESixty's Avatar
Attachment 16664
In your last post it is piece #5 which needs to be removed
Old Mar 17, 2006 | 05:56 AM
  #37
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
I have no actual experince removing the part but it says "raise cover" and shows an #5. Does that work?
Old Mar 17, 2006 | 11:42 AM
  #38
ATLESixty's Avatar
I was able to route the harness without removing the plastic trim. Thanks for your help Rudy.
socale39
Sep 5, 2023 08:30 AM
justoracle
Dec 10, 2015 07:16 AM
DetailersDomain
Detailing Forum
May 29, 2015 04:52 AM
carid
Apr 29, 2015 04:20 AM
fmusbmw
Bluetooth & Cell Phone Forum
May 14, 2004 11:41 PM
