Coolant expansion tank DIY?
Old Jul 2, 2013 | 01:04 PM
ASpec818's Avatar
My Ride: E60 545i
Default Coolant expansion tank DIY?
Is replacing the tank an easy DIY? my local bmw pros want $450 to replace it w/ a bleed. I found out the coolant stick was broken inside the tank.
Old Jul 2, 2013 | 01:48 PM
txag_530i's Avatar
It isn't hard. The basic steps:
Remove the plastic cover from underneath the car. Drain the radiator using the drain on the radiator. Replace the coolant overflow tank. Refill with a 50/50 mixture of coolant/water. Purge the air from the system. Replace the plastic cover.
See here for more details:
cooling-system-flush-refill-venting-system
You should probably replace the hoses to and from the tank while you're at it.
Old Jul 2, 2013 | 01:52 PM
ASpec818's Avatar
My Ride: E60 545i
wait, are those instructions to replace the tank?
Old Jul 2, 2013 | 02:04 PM
tonyb635's Avatar
If you have an electric water pump thn you can activate it using this procedure and it will circulated and remove the air.
Old Jul 3, 2013 | 09:52 AM
paran's Avatar
My Ride: 2005 545i Sport
Here's my detailed description of when I replaced mine:
https://5series.net/forums/e60-discu...9/#post1488696
Old Jul 4, 2013 | 12:17 AM
Boost7's Avatar
My Ride: E60
Model Year: 2005
this is a very simple DIY with basic tools, I changed mine out within 30mins.
Vman33
Mar 14, 2022 04:43 AM
Henry Peters
Sep 25, 2015 10:15 AM
timmay77
Sep 23, 2015 12:34 AM
ST JAMES
Sep 14, 2015 03:29 PM
InsipidMonkey
Sep 13, 2015 05:11 PM
