comfort access key fob battery replacement?
i have a 2007 525i with comfort access. its my understanding that if you have comfort access, the keyfob does NOT recharge when in the ignition.
ive done an exhaustive google search to try to find out how to replace the battery in the keyfob, but i have yet to find out 1. what size/model battery the keyfob takes, and 2. the procedure to open the keyfob and replace the battery.
any help is appreciated.
when you say "pop the cover open" do you mean pry apart the entire fob minus the metal key? whats the best way to do this without damaging the key? do you know any sites that have pictures on how to do this safely? i just dont want to damage my key and have to take it in to the dealer for reprogramming, which is what i hear needs to be done if you dont replace the battery within 1 minute.
ok i figured it out. thanks for the advice i finally dont have to use the key to unlock/lock my doors anymore! and unlock the doors before opening the trunk!
