Clutch Stop
Hi,
Has anyone installed a clutch stop in their E60? I've looked at a couple of DIY and aftermarket and they all assume an existing hole to screw a bolt into. I don't see that on our cars nor am I sure about a clutch stop working with the interlock switch that prevents the car from starting unless the clutch is fully depressed.
Thanks for the advice!
My Ride: 2006 530xi -- silver grey
I might too be interested in a clutch stop. The problem that I've noticed, however, is that the friction point (where the clutch engages the tranny) is so deep/towards the floor that perhaps a stop would prevent the clutch from fully engaging/disengaging.
Is it possible to alter the location of the friction point within the pedal's arc of excursion??
PelicanParts.com
09-10-2015 10:02 AM
