Cigarrette lighter 12Vdc outlet not staying up
Old 11-13-2009, 05:43 PM
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
I'm thinking of installing an iPhone dock and was curious to find out how to do it.
Besides, need to find out why that damn 12VDC ash tray outlet isn't staying up.
Lift the iDrive control knob up.
Press on the ash tray insert to remove.
Remove 2 torx screws.
Lift the wood trim carefully near the menu button.
Old 11-13-2009, 05:44 PM
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Reason why you want to lift here. Unplug wire from menu/voice buttons.
Remove 4 screws holding the ash tray. I used allen wrench to remove the 2 back screws.
Disconnect wire to the 12VDC cig. lighter outlet.
Old 11-13-2009, 06:01 PM
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Here's the culprit.
To fix, wind the spiral spring one more turn to pre-tension the outlet assembly to stay up if the ash tray door is open.
Now, It's time to order the Spec.Dock
Attached Thumbnails Cigarrette lighter 12Vdc outlet not staying up-step9a.jpg
Old 11-14-2009, 11:18 AM
richard313's Avatar
My Ride: 2006 550i 6spd
that deck looks awesome!
make sure to take pictures of it when it's done
Old 11-15-2009, 09:45 PM
jagbagri's Avatar
I'm thinking of getting one spec.dock as well. I could not fine a DIY for that.
It would be great if you could take alot of pictues and create one diy for spec.dock install.
Do you already have Dension-500 installed?
thanks
Old 11-12-2010, 03:24 AM
Pickle's Avatar
My Ride: 2006 530d M-Sport LeMans Blue
Just used this guide to fix my 'Floppy' Cigarette lighter!
Excellent stuff. Guides like this make it a DIY choice rather than an expensive trip to a Dealer or even specialist.
Old 12-29-2010, 11:54 AM
vrmoreno3's Avatar
My Ride: 2006 530i, Cold Weather, L7 sound, Bluetooth, Satellite, BMW Roof Rack
That was great. I cut my fingers up trying to get to the two back screws and wire harness. I broke a clip for the left seat heater but still works. I hope it never comes undone again.
Old 07-28-2011, 01:19 PM
neoe60's Avatar
Awesome write up!
I was able to get wedge pop off the trim around the shift knob with a plastic butter knife, but how did you pop off the wood trim by the menu button?
It's on there pretty tight, I'm just afraid of breaking or cracking the trim. Any tips?
Old 07-29-2011, 07:55 AM
BLooD's Avatar
I have had a specdock for quite a while, very easy to install and a great kit, the makes are really helpful.
Attached Thumbnails Cigarrette lighter 12Vdc outlet not staying up-img_0037.jpg   Cigarrette lighter 12Vdc outlet not staying up-img_0036-1-.jpg
Old 07-29-2011, 11:14 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Attachment 94269
Attachment 94270
Attachment 94272
Attachment 94271
Rizbel,
Can you please explain the step 2 (2nd photo): Press on the ash tray insert to remove a bit more detail?
Thanks,
Quick Reply: Cigarrette lighter 12Vdc outlet not staying up
