Changing the orange LED to white LED on the cluster to look like M5 or
Old 10-15-2013, 11:50 PM
  #351
pinguhk's Avatar
My Ride: Mini Cooper
Originally Posted by balbs
Red LEDs for the needles? I thought you can just color or install OEM M5 red needles?
colour it is much easier and you can have it any colour you what.
Old 10-16-2013, 06:39 AM
  #352
balbs's Avatar
My Ride: BMW
Already bought the M5 needles. I think it looks better.
Old 10-31-2013, 02:50 PM
  #353
GJacobs24's Avatar
My Ride: 2006 BMW 530xi loaded
Where are you located? Maybe we can work something out where I send you my cluster and you could do it for me? I'm on the east coast in MA. shoot me a price quote for the LEDs and labor if your up for doing it.
Old 11-03-2013, 01:49 PM
  #354
stel_i79's Avatar
My Ride: 530i N52
Engine: n52
u can go/send your cluster to JOHN in ny..
he did mine..and i love it
Old 11-26-2013, 05:30 PM
  #355
balbs's Avatar
My Ride: BMW
Default I Joined the Club!!!
Finally!
I've had the LEDs, reflective strip, and everything else for over a year and just barely had time to finally do this mod.
I enjoy the new look. Feels like I'm driving a different car.
For my mod I decided to not install the reflective strip for the rear dials. I figure the "darkness" sort of gives the front of the dial more depth. The reflective on the dials I feel may cause the numbers to get lost or blend too much into the whole whiteness.
Also, rather than giving the needles the Sharpie treatment, I installed OEM M5 needles instead.
For those of you that are thinking about doing it, DO IT! Also here's a little tip. Trying to solder the new LEDs on is a pain in the a$$! What I did was use a length of thin piano wire or very thin rod and tape it over the LEDs along the ends. The piano wire will have some tension when the ends are taped down so that it will hold the LEDs in place so you can solder it. A plus side is that it makes for a nice flush solder connection. See the pic.
Attached Thumbnails Changing the orange LED to white LED on the cluster to look like M5 or-cluster.jpg   Changing the orange LED to white LED on the cluster to look like M5 or-clusterled.jpg
Old 11-30-2013, 03:16 PM
  #356
Margal's Avatar
My Ride: 2005 E60 545i Manual, Sport, L7
Model Year: 2005
has anyone swept the board from original to m5 cluster? just wandering to get m5 cluster and exchange the board and LEDs. will it work without coding. also saw these on ebay 2004 2005 E60 BMW 5 Series 525i 530i 545i Instrument Cluster White Face Gauges | eBay has anyone used them?
Old 11-30-2013, 08:58 PM
  #357
stel_i79's Avatar
My Ride: 530i N52
Engine: n52
thats very intresting :
Old 12-01-2013, 05:40 AM
  #358
Margal's Avatar
Model Year: 2005
If the board is same size and it fits why it should not work? That white overlay I've posted looks like like dodge neon cluster.
Old 04-15-2014, 12:43 AM
  #359
bmwrider2010's Avatar
My Ride: BMW 550i
no no no. 1 you have to reprogram chip that holds data. 2. you need to code it to your car specifics.
if you plug it it will light up but will not work properly
Old 04-15-2014, 12:48 AM
  #360
My Ride: BMW 550i
Originally Posted by sdorian1983
finally found the LED type and what i can say its a huge difference will post some pictures next week !!!!
what is LED size for needles? on M5 they are red in standard e60 they are orange, I am thinking to swap them too to a brighter ones in red so the needles will be bright red.
also I have noticed it is hard to see red needles in day time for that reason M5 cluster coded that way so the backlight is always on as soon as you start the ignition. this can be done on e60 clusters too it just need one line to be changed to aktiv with ncs expert
Quick Reply: Changing the orange LED to white LED on the cluster to look like M5 or
