Changed the Oil in my 535i Today
My Ride: 2008 535i w/ Sports & Permium Pkg. Silv/Blk
2008 VW R32 w/Nav.
1992 VW Corrado Silv/Blk-retired
2001 530i Sports/Premium-retired
![Talking](https://5series.net/forums/images/icons/icon10.gif)
So 7,160 miles just ticked over on the odometer of our 08 535i, and since we intend to keep the car a long while I felt a mid interval oil change was in order. (BMW does one every 15,000 mls. under their 'free' maintainance plan.) I called my local SA and was told $110+tax which was fine with me, the only issue was finding the time to bring it in. But last week I came accross a post from member B767capt who did an oil change on his 535i, so I PM'ed him to inquire about the process, as I had done oil changes on all my other cars and felt up to the challenge. He told me it was easy so today I decided to do it, and share the knowledge with the forum.
Oil Filter =$11.08
7Qts BMW Oil =$40.53
Tax=$3.10
Total=$54.71
Not paying the dealership $62 to sit & wait for 2hrs.......priceless.
Tools & Part
1) Phillips head screwdriver
2) 8mm scoket & driver
3) 17mm wrench
4) Filter pulling tool
5) BMW Oil Filter
6) O-rings (included with filter)
7) Synthetic SAE 5w30 BMW oil (7 quarts)
8) Car jack
9) Wheel Block
10) Oil catch pan
11) Funnel
![Changed the Oil in my 535i Today-oil_change_016.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/43373d1482365851t-changed-oil-my-535i-today-oil_change_016.jpg)
The Process
1) Park the car on a level surface, start the engine and let it idle for 5 min. if car is cold, or cool down if hot.
2) Make sure the park brake is applied (manual trans. also engage 1st gear).
3) Wedge wheel block at the rear passenger side wheel.
![Changed the Oil in my 535i Today-oil_change_015.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/43359d1482365851t-changed-oil-my-535i-today-oil_change_015.jpg)
4) Jack the car up on the front driver side. (best for good oil drainage)
5) Place jack stand under car (if you have one) for added safety.
6) Locate the small trianglar pannel in the (second from the front) air management undertray.
![Changed the Oil in my 535i Today-oil_change_017.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/43360d1482365851t-changed-oil-my-535i-today-oil_change_017.jpg)
7) Using the 8mm socket, unscrew the 3 hex screws and remove the pannel, exposing the drain plug.
![Changed the Oil in my 535i Today-oil_change_012.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/43363d1482365851t-changed-oil-my-535i-today-oil_change_012.jpg)
![Changed the Oil in my 535i Today-oil_change_014.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/43364d1482365851t-changed-oil-my-535i-today-oil_change_014.jpg)
8) Place oil catch pan on old news papers (in case you missplace said oil pan like I did
) under drain plug and remove it with the closed end of the 17mm wrench.
9) Locate oil filter cap, round black plastic, top right of engine forward of air box.
![Changed the Oil in my 535i Today-oil_change_002.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/43365d1482365851t-changed-oil-my-535i-today-oil_change_002.jpg)
10) Place paper towel or rag around filter cap to contain any spills while removing the oil filter.
![Changed the Oil in my 535i Today-oil_change_003.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/43366d1482365851t-changed-oil-my-535i-today-oil_change_003.jpg)
11) Using filter wrench, unscrew the filter cap/holder, remove the old filter & O-rings then clean out the cap.
12) Locate the 2 new O-rings (supplied with new filter) & place them on the cap,
![Changed the Oil in my 535i Today-oil_change_004.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/43367d1482365851t-changed-oil-my-535i-today-oil_change_004.jpg)
![Changed the Oil in my 535i Today-oil_change_006.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/43368d1482365851t-changed-oil-my-535i-today-oil_change_006.jpg)
......then place the new filter in the cap.
![Changed the Oil in my 535i Today-oil_change_010.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/43370d1482365851t-changed-oil-my-535i-today-oil_change_010.jpg)
13) Apply a thin film of oil to the O-rings then screw the filter cap back in place, thighten. (Note, you should be able the screw the cap all the way down by hand, if not it could be cross threaded & will leak. Undo cap the all the way off then screw it on again.)
14) Replace & tighten the drain plug, taking care not to cross thread as above.
15) Add new oil.
![Changed the Oil in my 535i Today-oil_change_013.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/43371d1482365851t-changed-oil-my-535i-today-oil_change_013.jpg)
16) Replace the small panel (from #6), let the car off the jack.
17) Start the car & check for oil leaks (both at the filter & underneath at the drain plug.)
18) You are done!!
Please be responsible and dispose of the used oil in the proper way, (most auto parts stores will take & recycle your used motor oil) never throw it away in the trash.
I hope this helps....good look.
Oil Filter =$11.08
Tax=$3.10
Total=$54.71
Tools & Part
3) 17mm wrench
5) BMW Oil Filter
8) Car jack
9) Wheel Block
10) Oil catch pan
11) Funnel
![Changed the Oil in my 535i Today-oil_change_001.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/43372d1482365851t-changed-oil-my-535i-today-oil_change_001.jpg)
The Process
![Changed the Oil in my 535i Today-oil_change_011.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/43362d1482365851t-changed-oil-my-535i-today-oil_change_011.jpg)
![Changed the Oil in my 535i Today-oil_change_005__2_.jpg](https://5series.net/forums/attachments/diy-do-yourself-14/43369d1482365851t-changed-oil-my-535i-today-oil_change_005__2_.jpg)
15) Add new oil.
18) You are done!!
2008 VW R32 w/Nav.
Originally Posted by DRANGED' post='521611' date='Jan 22 2008, 11:42 PM
Nice work Phil ![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED)
Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres
Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres
Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
Thanks for the write up!!
My Ride: E60 530i
Engine: M54
Edit: Oil Filter =$11.08
7Qts Oil =$40.53
Tax=$3.10
Total=$54.71
Tools & Part
3) 17mm wrench
5) BMW Oil Filter
8) Car jack
9) Wheel Block
10) Oil catch pan
11) Funnel
Attachment 43372 Attachment 43373
The Process
Attachment 43359
Attachment 43360
Attachment 43362
Attachment 43363
Attachment 43364
Attachment 43365
Attachment 43366
Attachment 43367
Attachment 43368
Attachment 43369
Attachment 43370
15) Add new oil.
Attachment 43371
18) You are done!!
7Qts Oil =$40.53
Tax=$3.10
Total=$54.71
Tools & Part
3) 17mm wrench
5) BMW Oil Filter
8) Car jack
9) Wheel Block
10) Oil catch pan
11) Funnel
The Process
Attachment 43359
Attachment 43360
Attachment 43362
Attachment 43363
Attachment 43364
Attachment 43365
Attachment 43366
Attachment 43367
Attachment 43368
Attachment 43369
Attachment 43370
15) Add new oil.
Attachment 43371
18) You are done!!
First is the plastic shield under the engine. Mine is held by 2 clips and 1 philips screw. Once the philips screw is undone, pull the shield down. The shield is still attached to the big plastic cover under the engine.
Second is the drain plug, same size 17mm but is not pointing downard. It points kind of horizontal. So there is a chance of having used oil shooting to the big plastic shield under the engine.
Otherwise, the procedure is the same excepted that I drive the car onto ramp to do oil change.
Phill ! You have a career opportunity as a hand model............. watch out George Costanza !
ps. nice write up !
Cheers
ps. nice write up !
Cheers
2008 VW R32 w/Nav.
ps. nice write up !
Cheers
ps. nice write up !
Cheers
