Car Coding
#191
My Ride: 2012 535i M-Sport
Does anyone know if the AHL modules are called 'AHL' or something different in the ECU list? I want to look at them to try and code the Adaptive function on my LCI lights, but I have read every ECU in CAS and LMA - and nothing seems to be those little guys...
NCS is amazing other than this little hang-up...
#193
Engine: N54
#194
#195
Model Year: 2005
Engine: 545i
FSW_PSW.TRC.LMA.txt
This is from a 09/2004 with a full LCI retrofit (LCM2).
I never had welcome lights option in the idrive menu
CAPPL
VA_WELCOMELIGHT
nicht_aktiv
but everything works properly. I guess I can I add it but I'm not planning on switching them off ever...
![Happy](https://5series.net/forums/images/smilies/imported/happy.gif)
One thing that's not working is cornering lights
CAPPL
VA_CORNERINGLIGHT
activ
I activated it but still doesn't work - does anyone know if I need to add something to VO or make other changes? here's my CAPPL trace file in case anyone can shed some light on this...I wonder if it's got something to do with steering (is that the SZL module?)
FSW_PSW.TRC.CAPPL.txt
#197
Here's mine.
Attachment 116649
CAPPL
VA_WELCOMELIGHT
nicht_aktiv
CAPPL
VA_CORNERINGLIGHT
activ
Attachment 116650
Attachment 116649
CAPPL
VA_WELCOMELIGHT
nicht_aktiv
CAPPL
VA_CORNERINGLIGHT
activ
Attachment 116650
Thank you for your answer, i will take a look on your files and i will try to see if something is working on mine.
#198
Model Year: 2005
Engine: 545i
#199
Location: Calgary, AB - Canada / Buenos Aires - Argentina
My Ride: 2006 BMW M5
I am trying to find Welcome_Light_Active in LMA module. CAPPL is coded VA_Welcome.. nicht_akiv > aktiv and I can see it in iDrive but I need recode LMA but I can't find "Welcome_Light_Active". Here is the file attached.
I suppose to add VO code?
Original File of LMA Module: FSW_PSW.txt
the car is 2006 M5 (Nov 2005)
#200
Model Year: 2005
Engine: 545i
