cant get sss v32 to work with e60
My Ride: BMW 530D M-Sport, Steptronic, Grey Metallic,
Retrofits: Sport Comfort Black Leather, M-Sport Alu Cube Dash Trim, Shadow Line Trim, CCC Pro Nav, Full M5 Conversion, M5 Mirrors, Quad M5, 20" M5 Gloss Black wheels, AC High Panel, Internal Boot Release,
Mods: Xenons, Carbon Fibre Roof, Dension 500, Drilled & Grooved Discs,
hi guys just installed dis inpa and sss v32 on my new laptop i can get inpa to work dis and ncs
i can open sss v32 fine when i try to read my car goes through to reading vehicle order then it says i need ops whats wrong here?
i tried to add changes.iso not sure if this is the right one for E60 or do i need another changes.iso?
this is the error i get
You've done pretty well to get that lot running but your version of Progman seems too original. In theory the E60/E61 should not be programmed via the OBD2 socket. There's too much data and too great a risk of a problem. They should be coded via a fibre optic head connection which is what the software is saying.
I'm not 100% on this but I think a tweak is needed to the database behind Progman to allow OBD2 coding on the E60/E61.
Im sure some one know as i need to do a retro fit of cdc as i have changed my hu
Mine is running in vmware
Did you ever get an answer to your Question? I had this problem with V41 but in V32 it bypasses this and gives me an unknown data status prior to going into CKM settings. However, it works on other BMWs fine. I think because I had the car updated with an ICOM/A makes the car incompatible with the OBDII plug. You can update the car via OBD no problem actually. ICOM is really an OBD port hooked up to a WIFI chip with an internal harddrive which feeds back to the server...in a sense it is a client. You may be able to change a few settings in the VM to get this to work properly. PM me to discuss. You have to take baby steps and log everything you are doing and back out of changes....somewhat tedious for the non-programmer.
DavaiLave
08-02-2022 02:16 AM
