Bulb Cold/Warm Check
Here it goes...I'm almost sure all this info is out there but unfortunately I do not have time to search the forum much.
Does anyone know the lines of code to disable both the cold/warm check for all lights upfront? I am doing main beam, high beam, fogs and parking, I remember these for the angel eyes...
KALTUEBERW_SL_V_L
KALTUEBERW_SL_V_R
WARMUEBERW_SL_V_L
WARMUEBERW_SL_V_R
I have an 03 Z4M that I'm about to start a project on. Doesn't matter E85 just if you have the info, these things usually do not change much from year to year so if someone knows off hand or wishes to give a brother a search had I'd appreciate it so much.
basically need the abbreviations for FOG, Headlamps and parking...just like the SL_V is for angel eyes
RL_BL_PARKL_FKT
BL_2_PARKL_FKT
I believe is for parking? So on and so forth......
THANKS!
KALTUEBERW_SL_V_L
KALTUEBERW_SL_V_R
WARMUEBERW_SL_V_L
WARMUEBERW_SL_V_R
RL_BL_PARKL_FKT
BL_2_PARKL_FKT
THANKS!
I think in our car they are:
... if you disabling the cold/warm check might wanna also disable the warning w/ FEHLERMELDUNG_CC_
GL!
Code:
FL_R/L = high beam AL_R/L = low beam NSW_R/L = fogs SL_V_R/L = parking/AE
GL!
Hi guys I found these values and tested all is working perfect actually with no modifications needed. But in the event anyone needs these are what I've found from reading the module out. Again this is for E46,E39,E85,E86, and probably some early model E53. You'll have to read your modules to find out. Look all translated and formatted for you but too bad I got lazy toward the end. Sorry!
KALTUEBERWACHUNG_AL Cold testing low beams.
KALTUEBERWACHUNG_BL Cold testing brake light
KALTUEBERWACHUNG_BL_MI Cold testing third brake light
KALTUEBERWACHUNG_BLK_HI Cold testing rear turn signal
KALTUEBERWACHUNG_BLK_VO Cold testing front turn signal
KALTUEBERWACHUNG_FL Cold testing high beam
KALTUEBERWACHUNG_KZL Cold testing license plate lights
KALTUEBERWACHUNG_NSL Cold testing fog lights.
KALTUEBERWACHUNG_RL Cold testing reverse lights
KALTUEBERWACHUNG_RL_LI Cold testing reverse light left.
KALTUEBERWACHUNG_RL_RE Cold Testing reverse light right.
KALTUEBERWACHUNG_SL Cold testing parking lights.
WARMUEBERWACHUNG_AL Warm testing low beams
WARMUEBERWACHUNG_BL Warm testing brake light
WARMUEBERWACHUNG_BL_MI Warm testing third brake light
WARMUEBERWACHUNG_BLK_HI Warm Testing rear turn signals
WARMUEBERWACHUNG_BLK_VO Warm testing front turn signals
WARMUEBERWACHUNG_FL Warm testing high beams
WARMUEBERWACHUNG_KZL_LI Warm testing license plate light
WARMUEBERWACHUNG_RL_LI Warm testing reverse light left
WARMUEBERWACHUNG_RL_RE Warm testing reverse light right
WARMUEBERWACH_ZUSATZ_BLK
WARMUEBERWACHUNG_NSL_LI
WARMUEBERWACHUNG_RL_2_RE
WARMUEBERWACHUNG_RL_3_LI
WARMUEBERWACHUNG_RL_3_RE
WARMUEBERWACHUNG_SL_LI
WARMUEBERWACHUNG_SL_RE
Model Year: 2010
These are my notes from coding LMA. These translations are also found in the file TRANSLATIONS.CSV distributed with NCSDummy.
HTML Code:
;Check Control parameters FEHLERMELDUNG_CC_AL_L low beam left FEHLERMELDUNG_CC_AL_R low beam right FEHLERMELDUNG_CC_BLK_H_L turn signal rear left FEHLERMELDUNG_CC_BLK_H_R turn signal rear right FEHLERMELDUNG_CC_BLK_V_L turn signal front left FEHLERMELDUNG_CC_BLK_V_R turn signal front right FEHLERMELDUNG_CC_BLK_Z_L turn signal sidemarker left FEHLERMELDUNG_CC_BLK_Z_R turn signal sidemarker right FEHLERMELDUNG_CC_BL_L brake light left FEHLERMELDUNG_CC_BL_M_1 brake light middle / center FEHLERMELDUNG_CC_BL_R brake light right FEHLERMELDUNG_CC_FL_L high beam left FEHLERMELDUNG_CC_FL_R high beam right FEHLERMELDUNG_CC_KZL_L license plate light left FEHLERMELDUNG_CC_KZL_R license plate light right FEHLERMELDUNG_CC_NSL_L fog light rear left FEHLERMELDUNG_CC_NSL_R fog light rear right FEHLERMELDUNG_CC_NSW_L fog light front left FEHLERMELDUNG_CC_NSW_R fog light front right FEHLERMELDUNG_CC_RFS_L reverse light left FEHLERMELDUNG_CC_RFS_R reverse light right FEHLERMELDUNG_CC_SL_V_L parking light front left FEHLERMELDUNG_CC_SL_V_R parking light front right FEHLERMELD_CC_BLK_V_L_2 turn signal front left 2 FEHLERMELD_CC_BLK_V_R_2 turn signal front right 2 FEHLERMELD_CC_RL_BL_1_L tail light 1 left FEHLERMELD_CC_RL_BL_1_R tail light 1 right FEHLERMELD_CC_RL_BL_2_L tail light 2 left FEHLERMELD_CC_RL_BL_2_R tail light 2 right ;Cold Monitoring parameters KALTUEBERWACHUNG_AL_L low beam left KALTUEBERWACHUNG_AL_R low beam right KALTUEBERWACHUNG_BLK_H_L turn signal rear left KALTUEBERWACHUNG_BLK_H_R turn signal rear right KALTUEBERWACHUNG_BLK_V_L turn signal front left KALTUEBERWACHUNG_BLK_V_R turn signal front right KALTUEBERWACHUNG_BLK_Z_L turn signal sidemarker left KALTUEBERWACHUNG_BLK_Z_R turn signal sidemarker right KALTUEBERWACHUNG_BL_L brake light left KALTUEBERWACHUNG_BL_M_1 brake light middle / center KALTUEBERWACHUNG_BL_R brake light right KALTUEBERWACHUNG_FL_L high beam left KALTUEBERWACHUNG_FL_R high beam right KALTUEBERWACHUNG_KZL_L license plate light left KALTUEBERWACHUNG_KZL_R license plate light right KALTUEBERWACHUNG_NSL_L fog light rear left KALTUEBERWACHUNG_NSL_R fog light rear right KALTUEBERWACHUNG_NSW_L fog light front left KALTUEBERWACHUNG_NSW_R fog light front right KALTUEBERWACHUNG_RFS_L reverse light left KALTUEBERWACHUNG_RFS_R reverse light right KALTUEBERWACHUNG_SL_V_L parking light front left KALTUEBERWACHUNG_SL_V_R parking light front right KALTUEBERW_BLK_V_L_2 turn signal front left 2 KALTUEBERW_BLK_V_R_2 turn signal front right 2 KALTUEBERW_RL_BL_1_L tail light 1 left KALTUEBERW_RL_BL_1_R tail light 1 right KALTUEBERW_RL_BL_2_L tail light 2 left KALTUEBERW_RL_BL_2_R tail light 2 right ;Hot Monitoring parameters WARMUEBERWACHUNG_AL_L low beam left WARMUEBERWACHUNG_AL_R low beam right WARMUEBERWACHUNG_BLK_H_L turn signal rear left WARMUEBERWACHUNG_BLK_H_R turn signal rear right WARMUEBERWACHUNG_BLK_V_L turn signal front left WARMUEBERWACHUNG_BLK_V_R turn signal front right WARMUEBERWACHUNG_BLK_Z_L turn signal sidemarker left WARMUEBERWACHUNG_BLK_Z_R turn signal sidemarker right WARMUEBERWACHUNG_BL_L brake light left WARMUEBERWACHUNG_BL_M_1 brake light middle / center WARMUEBERWACHUNG_BL_R brake light right WARMUEBERWACHUNG_FL_L high beam left WARMUEBERWACHUNG_FL_R high beam right WARMUEBERWACHUNG_KZL_L license plate light left WARMUEBERWACHUNG_KZL_R license plate light right WARMUEBERWACHUNG_NSL_L fog light rear left WARMUEBERWACHUNG_NSL_R fog light rear right WARMUEBERWACHUNG_NSW_L fog light front left WARMUEBERWACHUNG_NSW_R fog light front right WARMUEBERWACHUNG_RFS_L reverse light left WARMUEBERWACHUNG_RFS_R reverse light right WARMUEBERWACHUNG_SL_V_L parking light front left WARMUEBERWACHUNG_SL_V_R parking light front right WARMUEBERW_BLK_V_L_2 turn signal front left 2 WARMUEBERW_BLK_V_R_2 turn signal front right 2 WARMUEBERW_RL_BL_1_L tail light 1 left WARMUEBERW_RL_BL_1_R tail light 1 right WARMUEBERW_RL_BL_2_L tail light 2 left WARMUEBERW_RL_BL_2_R tail light 2 right
Hi guys.
I woul like to know if there is difference between henon and halogen headlight coding. I think there is one, because I codded my LM1 on my 2006' e60 520dA (halogen headlights) like this:
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
Unfortunately, this job works only for outside AE: the inside AE are still flashing just after START and so there's a error message when I remove one of them to simulate failure ...
I feel one or three lines are missing to obtain a correct coding.
I think it could be right for e60 with only one bulb by pair of AE (by side).
Is there lines that I have to code additionnal to this, please ?
Many thanks for advance.
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
nicht_aktiv
Hi everybody !
Little feedback:
Supposed you have this (this is my case):
RL_BL_2_ALS_SL_VORNE (INNER TAIL LIGHTS AS FRONT STANDING LIGHTS)
aktiv
So, for halogen headlights, you must add this:
aktiv => nicht_aktiv
That works for me ! no more flashing light in AE, and no more message if I simulate a failure removing a led in my (inner) AE ... great !
Little feedback:
aktiv
My Ride: Honda Civic Sport
Hi all, i am new to this forum, does anyone know how to code out the warm and cold dipped beam checks on an BMW F10 2010, if i could get a step by step guide it would be much appreciated.
or if someone here knows anyone in the UK West Midlands and can direct me to him/her that would be great.
I have installed an H7 LED kit but getting warnings on the odd occasion and light flicker every once in a while. Don't wish to go back to halogen if possible.
Many Thanks in advance.
Adeel
Adeel
