Brake Pads
#21
My Ride: BMW E60 530i , Silver with leather Air Con iDrive 17" Breyton Rims with Dunlop Sp Sport tyres (M-Tech Bodykit and rims WANTED)
Alfa Romeo 147 TS1.6 , Black with Air Con 17" Multi Spoke alloys with Bridgestone RE040 tyres
Toyota MR-S 1.8 VVTI , Lagoon Blue with Red leather Air Con 15" standard alloys with Toyo tyres
Toyota Celica 1.8 VVTI, Lagoon Blue, Air Con, 16" Standard alloys with Kuhmo KU31, EBC Green Stuff
good brakes instead of excellent brakes is the price you pay for les brake dust , having said that , it can take a while for a pad to wear in ,
i usually go for ebc brakes on past cars , generally opting for greenstuff over red , for less brake dust than stock pads but more than redstuff ,
#22
This is so frustrating for me - reading this thread, first the Axxis deluxe pads are great, then someone says they aren't better than stock?!?!?!
I think I'll go with the Hawk pads after all - SCCA chose them, they can't be that bad...
#23
My Ride: 05 545i 6MT
Even you go w/ Hawk (SCCA recommended), it also depends on which pads you get.
If you get Hawk Ceramic then it's probably less brake than BMW OEM just like the Axxis Deluxe as they are designed for more of "OEM" replacement (OEM here means OE of "normal cars").
BMW OEM Sport package pads are not normal and it's actually pretty good (that's why it's DUSTY)
If you are doing AutoX/Track Day try your STOCK pads first and see if you are satisfied
(don't forget to flush the brake fluid too)
Then when you feel you need better brakes then try Hawk HPS or EBC Red if you want to do LIGHT track day/Autox.
Then if you feel you need more bite, then go w/ Hawk HP+ or EBC Yellow (if they made one for E60) - this is one step prior going to track compound which usually squeeks.
Aggressive: EBC Yellow / Hawk HP+
More aggressive: EBC Red (my choice)/Axxis Ultimate dust like crazy but cheap!
Mid aggressive: Hawk HPS (my choice)
Less aggressive: EBC Green probably same as BMW OEM Sport
Commute car quiet/low dust: Hawk Ceramic/Axxis Deluxe/EBC Ultimax (maybe same brake power as non sport BMW)
Just keep in mind the better the braking = dustier = noiser
#24
Just keep in mind the better the braking = dustier = noiser![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
I have tried braking hard with the OEM brakes last summer, and on a course with lots of elevation changes, pretty difficult route with lots of braking points - OEMs faded a LOT, I thought. Basically, I don't really care about the dust - I'm going either gunmetal or black with my rims anyway, so it won't even show so much. Just not sure whether the extra few bucks for the Hawks is really worth the diff...
#25
Thanks! I'm literally almost pulling the trigger on the Stoptech Premium Perfomance pads and now I've got to consider whether to go Hawk or not after all.
I had Hawk HPS on my STI before and I felt they are still geared toward performance street or AutoX (which usually doesn't go over 60 mph w/ downhill braking).
#26
Confusing thread. so if I want:
- similar to stock (for performance and rotor wear) but less dust? Does it exist?
- more bite than stock but no more severe rotor wear?
or the least dust possible?
#27
possible. most popular pad that our customers have gone with have been the posi-quiets, which we personally run too or have ran with. they do reduce brake dust and some feedback we've had is that the performance is about the same as stock if not a tad better. for our customers who have wanted more bite, we set them up with the Axxis Ultimates.
#28
I ended up going with a set of Hawk HPS pads and Centric Drilled and slotted rotors. So far, the pedal is numb and I've been told it is due to Hawk HPS pads, but I'm hoping that once they are broken in, I'll bed them in and they'll bite very well. As a matter of fact, I already feel that the initial bite is stronger than the stocks that I replaced. I'll start a new thread to report the details of my experience with these brakes when I get more time behind the wheel with them - so far it is both a little cold out and the brakes are brand new = feel numb, brake "lazily".
#29
My Ride: 2005 530i...just bought so in progress...dont know where to start???
Want to do:
LCI Tails, Xenon Headlights, Tints, Wheels, Trunk and Roof Spoiler, iPod Adapter...the list goes on.
hey guys when your sensor says you need to replace your pads do you need to buy a new sensor or can the sensors be re-used??
thanks
thanks
