Brake Pad Change
My Ride: 545i - ordered in January delivered April 21st! Black Sapphire Metallic, Black Dakota Leather, Anthracite Maple.
Has anyone changed their own brake pads? Any special tools needed?
My Ride: G30 M550i
Model Year: 2018
Front brake pads:
http://forums.e60.net/index.php?autocom=ga...i&img=11629
Front brake discs:
http://forums.e60.net/index.php?autocom=ga...i&img=11626
Rear brake pads:
Rear brake discs:
The most challenging issues include:
You'll have to reset the condition based service monitoring in iDrive - instructions on how to do that are posted somewhere.
Good luck!
- Removal of the locking hex socket holding the disc on. If it's been a while these can be "frozen" in place. Use plenty of WD-40 or similar, soak them really well (even overnight) before trying to loosen. Don't strip them out or you're in for a hunt for a screw extractor.
- Next, when reassembling, is to use the proper high temp anti-seize and anti-squeal product as indicated in the PDFs Rudy was kind enough to post.
- IMHO, replacing of the sensor is going to cost you a few extra $$$s but they have been heated and cooled for thousands of miles and it's only plastic - get a new one!
- If you are on your second pad change it's probably a good idea to replace the rotors too. In any case if there are deep grooves or they are worn thin they should be replaced.
- The only special tools you'll need are a set of metric hex keys to remove the brake disc and caliper; you can usually jury rig something to press the piston back into the caliper - be sure to suck out some brake fluid from the master cylinder so you don't over flow it when the fluid is pushed back - especially if it had been topped off some time in the recent past.
Good luck!
My Ride: 04' 530i Sport/premium/cold wx/PDC/xenon.
This is what I miss about my new E90.
You just don't see this level of help from members on these other boards.
Tip of the hat to you guys
UltimatePeter
DIY: Do It Yourself
09-28-2015 09:12 AM
TexaZ3
05-06-2015 09:54 AM
