Battery Replacement Experience
Old Oct 25, 2015 | 09:25 PM
E61FUN's Avatar
My Ride: white
Model Year: 1947
Engine: b38
Default Please delete thread.
Old Oct 26, 2015 | 04:01 AM
JayArras's Avatar
Administrator
My Ride: 530xi
Engine: N52
Thank you for the excellent write-up and photos! I moved your post to the DIY section where I think more people will benefit from it.
One question though, why did you select the Exide Edge AGM FP-AGML5/49 over the others?
Old Oct 27, 2015 | 03:35 AM
JayArras's Avatar
Administrator
My Ride: 530xi
Engine: N52
Originally Posted by E61FUN
Batteries Plus Bulbs had the cheapest price and didn't require a core charge or the return of my old battery. So the old battery went to a lead recycler that paid a nice core charge.
In Connecticut, retailers don't require a core charge, but give you $5 - $10 off the price of the battery if you give them your old one. How much does one get from a lead recycler if they were to bring the old battery to them themselves?
Old Nov 6, 2015 | 06:26 AM
txag_530i's Avatar
I chose to add in wiring for a little DieHard 3amp trickle charger. The images below depict Rev1 wiring. Rev2 wiring will use a different plug style, larger gauge cable and eyelets, which will allow for better jumping from compact LiON battery packs. I wonder that low battery jumping is better accomplished out front in the engine compartment, nearer the starter motor. While trickle charging could be done from either end, the losses when hooking up in front and pushing trickle current all the way back to the battery slows the charging process, in my experience.
The potential for an explosion from any battery gases is admittedly quite small, but is a risk nonetheless. It is therefore not a good idea to jump or charge the battery at the battery terminals. Charge or jump the battery from the engine bay.
Old Sep 14, 2016 | 08:48 PM
mayanktanwar's Avatar
My Ride: I have BMW 5 Series 520i
Default Battery Replacement
Last month i replaced battery of my BMW 5 SERIES 520I, EXIDE MTDIN100 from BatteryBhai.com online. Their experts technition replaced it smoothly and they carry service battery also. First they installed service battery then replaced it. I asked them why they installed service battery, they told me service battery is installed because electronic system of my car remain same and i loss nothing. I'm quite impressed of using their technique for replacement of battery.
JonathonK
Mar 27, 2015 08:13 AM
das
10
Nov 2, 2004 08:28 AM
Farbton
19
Oct 22, 2003 11:21 PM
reckamech
Sep 8, 2003 01:24 PM
das
Jul 7, 2003 02:53 PM
