Battery Replacement
#71
Hello
Marc could you please repost a link to you picture I try to click on it and it state that it cannot find your page.
Thank you
Kenneth
P.S. I have 530I 2006 would Welker battery or Kragen battery be the to main battery to replace the original with
Thank you
Kenneth
Originally Posted by RatherBeInCabo' post='762866' date='Jan 8 2009, 02:11 PM
Well I had the experience of my battery dying on me while at the car wash this past weekend. I called the sealer and they wanted $500 plus to exchange the battery. I started looking online for information on how to do this and I found a ton of opinions...from doom and gloom to piece of cake. After reading through many posts on multiple sites and what was described in the manual, I decide I could do it myself. I purchased a Werker 95R from Batteries Plus and was on my way.
Many people warned that the battery needed to be registered with the car or I would lose all Idrive control if I do it myself. I can tell you now that is all BS and you can do it yourself in about 30 minutes or less. I took a little longer because I took pictures at each step along the way.
Here is the link to the pictures: http://gallery.me.com/ratherbeincabo#100032
If anyone has questions, I will be glad to answer them. You can email me at my username here at gmail.com
Marc
Marc
#72
Hi,
Thanks for the pics and instructions. I replaced the battery on my '06 530xi w/idrive and 6speed.
Only problem is that I have an "AWD, DSC, ABS, EBV" fault that won't go away.
Anyone know how to reset this?
I've attached a couple pics one from the instrument panel and the other from idrive.
Thanks!
Thanks!
#73
Originally Posted by rjbmw' post='888592' date='May 24 2009, 04:08 PM
Hi,
Thanks!
Attachment 80191
Attachment 80192
Thanks!
Attachment 80191
Attachment 80192
Try turning the wheel all the way to the right and then all the way to the left with the vehicle running after startup.
#74
Marc
Marc
Matt
#75
My Ride: 2004 545i — Sapphire Black | Sport | Premium |
Wheels & Suspension — DCR Nurburgring Satin Finish with Chrome Lip 20x9 front 20x10.5 rear | Toyo Tires 245/30/20 front 285/25/20 rear
Performance — In the Works: RPI Exhaust | RPi Ram Air Induction
Exterior — Onex 4300K Fog lights | Stage 3 tint all around | M-Tech kit |
Sounds - Alpine amps | Memphis Audio Front and Rear | Kicker Subwoofer | Stealth Box |
Marc
Marc
#76
My Ride: 2005 545i - Jet Black | bld 01/2005 | Black Dakota Leather | Sport Package | Cold Weather Package | NAV | Sports Seats | Sirius Satellite | Logic 7 | Multi-Disk | Shades | STEPTRONIC | Adaptive Xenons | Anthracite Maple | K&N Filter - Charcoal removed | Pinnacle 35% Tint | Blackout Kidneys | Black Calipers | Dinan Throttle Body | Dinan Pedals | EU Safety Triangle | e60 Clings | RPI Scoop | Black/white roundels | LED Interior Light Update
CIP 31.2
Marc,
Same thing happened twice to me in the last week. The battery died on the car when my wife had it and had to jump the car. Seemed good for a week then same thing happened today. Time for a new battery (these things are large at ~65lbs).
I did a couple of searches and found your other link (here) on this topic and was fantastic help. I had it out in under 10 min, called a local Batteries+ and after getting home, back in the car again in under 10. Active steering reset (and the clock) were the only items that popped up and works great!
Saved a TON of $ as a quick and easy DIY thanks to your initial efforts!
#77
My Ride: 2006 550i
Marc
Marc
#79
My Ride: 525i
Is it possible to refill a 2004 e60 battery with distilled water and then charge it in order to bring it back to a full charge? My battery warning indicator flashed after I had some music playing in the car while the engine was off (i know very stupid..) I ended up draining most of the battery. Will a simple re-charge do? Or do I also have to add distilled water to it? I know on the old batteries the caps can be unscrewed and you can refill the elements, but on my battery there are no caps on top under the stickers. So how else do you refill it?
#80
2. If it does not hold charge, replace it.
3. Old trick: Remove tops of battery (if possible).
4. Turn battery upside down in a large plastic container.
5. Lead flakes will fall out.
6. Refill with water and charge on trickle charger.
7. If you are lucky, battery will hold charge for 6 months or so with regular use.
8. Much simpler to replace battery.
Most batteries fail after 36 to 48 months.
