Battery Replacement
Old 01-08-2009, 12:54 PM
545felix's Avatar
My Ride: 05 545/6
Originally Posted by OverSoft' post='762884' date='Jan 8 2009, 02:30 PM
What does the little wire connected to the side of the battery do and where does it go?
if you mean the grey one, that is the vent tube. it goes out of the car. you need to connect this to prevent the buildup of hydrogen in the trunk.
the werker battery has the connection for the vent tube.
Old 01-08-2009, 12:57 PM
RatherBeInCabo's Avatar
A trunk full of hydrogen could cause an unpleasant experience
Marc
Old 01-08-2009, 08:12 PM
Isay5's Avatar
Originally Posted by RatherBeInCabo' post='762866' date='Jan 8 2009, 02:11 PM
Well I had the experience of my battery dying on me while at the car wash this past weekend. I called the sealer and they wanted $500 plus to exchange the battery. I started looking online for information on how to do this and I found a ton of opinions...from doom and gloom to piece of cake. After reading through many posts on multiple sites and what was described in the manual, I decide I could do it myself. I purchased a Werker 95R from Batteries Plus and was on my way.
Many people warned that the battery needed to be registered with the car or I would lose all Idrive control if I do it myself. I can tell you now that is all BS and you can do it yourself in about 30 minutes or less. I took a little longer because I took pictures at each step along the way.
Here is the link to the pictures: http://gallery.me.com/ratherbeincabo#100032
If anyone has questions, I will be glad to answer them. You can email me at my username here at gmail.com
Marc
Thanks for this. Saved in "just in case" file.
Old 01-08-2009, 08:44 PM
stankustov's Avatar
My Ride: 2004 BMW 530iA, sport package, premium package
Unhappy
Hello everyone. I just wanna let you guys know, recently i changed battery on my 04 BMW 530(i did it myself) and went through same things as described in this post above, ACTIVE STEERING is working fine, and after i changed the battery i found out that new battery has to be programmed on cars computer, and i was like: whatever - everything working just fine, and in about one month my iDrive controller started dieing, right now its working only up, down, right, left. After i read this post i think may be thats why my iDrive control has died. But i don't know was it related or no.
P.S. you can read about my iDrive here: http://forums.e60.net/index.php?showtopic=68365
Old 01-09-2009, 04:54 AM
AlexFW's Avatar
Model Year: 2005
Which battery does my 545i have?
How many batteries the E60 has?
Can I get one bigger?
Maybe for Canada and cold places there is an enhanced battery.....
Edit:
http://bmwfans.info/original/E60/Lim/545i-...61/ill-61_1853/
80, 90 and 110. What do I have now?
Old 01-09-2009, 05:49 AM
Edit:
Click this link: http://www.eastpenn-deka.com/default.aspx?pageid=454 and then select the PDF on the left side titled "Exact Fit Batteries". The one for the 545i is second from the bottom which is the 95R. This is the battery made for BMW and Werker. I do not think there is one bigger. The E60 has only one battery.
Old 01-09-2009, 06:32 AM
AlexFW's Avatar
Model Year: 2005
From part numbers, the E60 has 3 batteries...
Old 01-09-2009, 06:34 AM
porsche911targa's Avatar
Marc
Thank you very much for your insightful post. I was debating whether or not I should have the dealer do the work, but thanks to your post, I will see if my independent BMW shop would use this battery instead.
Old 01-09-2009, 07:27 AM
salaki's Avatar
My Ride: 05 545i 6MT
Read this post:
http://forums.bimmerforums.com/forum...d.php?t=644889
http://forums.bimmerforums.com/forum...d.php?t=570051
Old 01-09-2009, 07:42 AM
Originally Posted by salaki' post='763631' date='Jan 9 2009, 08:27 AM
Those posts are are some of the ones I used to get my information. However, they are about 3 years old so the prices mentioned are way off. A lot of people used the Autozone Duralast 49DL and I believe it does meet the specs. Problem is that it is not an exact fit. I prefer not to use wood shims. The Werker is and exact fit for the 545i and that is why I went that route.
Marc
Quick Reply: Battery Replacement
