Battery Charging
My Ride: 2006 550i
I just bought a battery charger/maintainer. My question is can you charge the battery under the hood or do you need to acces it in the trunck.
I noticed the positive acces pin under the hood, but no negative side...Is there one under the hood?
Thanks
Thanks
Thanks
Thanks
it sounds like you have found the positive terminal, the negative is just to the right of it.
It looks like a long bolt with a hex head and no thread, it's literally within 3 or 4 inches of the positive terminal.
Poolie
It's on the right side of the driver's side shock tower maybe 6-8 inches to the right from the red positive cover. It's not painted.
Originally Posted by sixcard' post='1024006' date='Oct 3 2009, 08:43 PM
I hard wired mine in the trunk.
sixcard![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
sixcard
Only the whole fscking chassis. Pick anything shiny/metal.
Seriously guys... Are most folks here unable to understand the simplest component of their cars? WTF?
My Ride: 08 550 Carbon Sport Almost everything factory, but no sound upgrades.
Originally Posted by CWS530' post='1024084' date='Oct 4 2009, 12:21 AM
Have you made through any check points with that "rig" John? ![Tongue](https://5series.net/forums/images/smilies/imported/tongue.gif)
sixcard
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by Iceman' post='1024214' date='Oct 4 2009, 12:38 PM
This way you are ruining your battery since the amount you charge will not be recognized!
The reason for the poles under the bonnet, is because batteries give off hydrogen gas when charging, and when you disconnect/reconnect the charging leads there is normally a spark.
This spark, even if tiny, is enough to blow the top off the battery and cover you in sulphuric acid, not to mention the flash burns from the gas igniting.
As the meercat says "simplessss"
Model Year: 2013
Originally Posted by chris f' post='1024230' date='Oct 4 2009, 03:37 PM
Not strictly true, nothing "recognises" the charge.
Yes it is true on the E60!
If you charge the battery directly, not through the poles under the hood, the computer doesn't recognizes it and will still act as if the battery is uncharged. This leads to a memory effect fast.
The power system on the E60 needs to recognize the charge and therefore it needs to be done through the poles under the hood, which are actually NOT designed for recharging, they are there for jump starting.
