Anybody replace the rubber seal around the door
Just wondering if anyone has replaced the soft rubber seal around the doors entrance, I noticed mine is ripped and causing a bad seal around the door. Ill post a pic later. Wondering if anyone attempted it? Easy or hard or take to dealer?
My Ride: 2004 BMW 545i Silver,Gray, Metallic. Blk Dakota leather. Nav. Heads up disply. PDC. Pro logic 7 sound. 35% tint.
Mods. MTECH body kit. OEM trunk finisher and M5 spoiler.OEM 166 wheels. Blk and wht CF Roundels.
Orion V2 AEs. LCI taillights with Ricky effect. LED interior lights. LED license plate light. HID fogs. Smoked LED side markers. White cluster mod. Coding. RPI scoop & BMC filter. Gloss black OEM grills.CF interior trim. B&B exhaust.
I did it. The seal was $60.
You have to take off the door sill.
It is a little tough. It just snaps off but be careful not to break the tabs.
Then you just pull the old rubber off and work the new one into place.
You have to work with it a bit to get it right and it is a little tricky around the corner of the dash
but you can do it. Good luck!
Did you need a screwdriver or any tool to remove/wedge the door sill out or did you do it by hand? also at what point did you start with the seal?? bottom or top?
Used a small pry tool. Started the seal at the bottom center.
Good luck.
Good luck.
turboawd
Aug 23, 2017 12:27 AM
