ALternative OEM shortshifter
Old 07-28-2009, 07:06 PM
  #31
richard313's Avatar
My Ride: 2006 550i 6spd
will this fit on 2006 550i?
Old 08-09-2009, 02:11 PM
  #32
545felix's Avatar
My Ride: 05 545/6
I finally got the shifter bent and I put it back in this afternoon. here's a few pictures for reference.
bottom is the stock pre- 03/05 shifter, middle is the 678 shifter (nearly identical to 373) and on top is the Z4 3.0, now bent.
here is the shifter in neutral (3rd/4th gate)
here is the shifter in 2nd
here is the shifter in 5th
and here's a side shot of my new stubby little shift lever, in neutral:
Old 08-27-2009, 03:13 PM
  #33
mrfva's Avatar
My Ride: .
Model Year: .
Very nice Felix Difficulty rating on a scale of 1-10?
Old 08-28-2009, 05:21 AM
  #34
545felix's Avatar
My Ride: 05 545/6
bending the lever was actually quite easy, but that's because I went to a local shop that has a jig set up specifically to bend them. the install took about 20 minutes, I've done it so many times now it's old hat. you basically have to buy a couple of extra clips and a replacement carrier, as you will likely damage the carrier on removal and you WILL drop a clip or two into the transmission tunnel area. The last time I did it, I used a set of extra long tweezers rammed into the clip to hold it in place while I slid it onto the selector rod and it worked like a champ.
I've found that the ZHP shift knob makes the shift effort too hard. So, I got the weighted M knob but in the taller version, 25 11 7 896 884. shifts aren't quite as short, but the knob still sits about 1/2" shorter than the 678 with the ZHP knob, and the effort is non-existent. it's like butter going into the gears, even less effort than the 678/ZHP setup. I must admit the ZHP knob looks better, especially with that metal ring around the bottom, but the shift effort difference is significant.
Old 09-02-2009, 07:59 PM
  #35
Troush's Avatar
Felix, I got my Z4 3.0 today and will be replacing it this weekend, how can I get the carrier out without tearing it up? If I do tear it up, how much is the replacement? Why did you bend your shifter?
Old 09-06-2009, 04:53 PM
  #36
Troush's Avatar
Chesney,
I just wanted to thank you! With your help and suggestions I finished putting in my Z4/3.0 shifter last night and got to drive it today...IT IS GREAT!!
I love it. I went ahead and bent it as much as possible to to look like the OEM shifter. I will keep you what else I do.
Thanks again!
Tobey
Old 02-14-2011, 09:28 PM
  #37
v_therussian's Avatar
Ordering parts for this mod, can someone confirm the part numbers?
Do I need:
25117534942,25111222015 and 25111220600 ?
What are the clips that I need to have a few extra of?
These: 25117571899?
TIA
socale39
09-05-2023 08:30 AM
Inness13
06-15-2016 12:47 PM
E60I
04-30-2015 05:07 PM
E60Japanese
03-23-2015 05:23 PM
choi000
10-17-2004 05:11 PM
Quick Reply: ALternative OEM shortshifter
