AHL unit removal for pre 03/2005 with adaptive headlights for LM1 to LM2 changes
Old 12-10-2021, 03:24 AM
  #41
smartshah's Avatar
My Ride: 535d M Sport
Originally Posted by Seba9009
I have.
You can search the LM file and using the search function. Keyword is AHL
Old 12-10-2021, 03:26 AM
  #42
Seba9009's Avatar
My Ride: E60
Thank you very much for your time. I will be by the car soon, I will let you know. may that be it.
Old 12-10-2021, 03:29 AM
  #43
smartshah's Avatar
It is called ALC_SG_VERBAUT - Adaptive Headlights (AHL) Control Unit Installed.
just tick nicht_aktiv.
You then should not see a AHL unit in ISTA. LM2 controls that after 03/2005.
Old 12-10-2021, 06:20 AM
  #44
Seba9009's Avatar
My Ride: E60
I turned off ALC_SG_Verbaut. The 9CC6 error is not there. But I have 9CBC and 9CBF now.
Old 12-10-2021, 06:22 AM
  #45
smartshah's Avatar
Can you screenshot the errors please
Old 12-10-2021, 06:29 AM
  #46
Seba9009's Avatar
My Ride: E60
Old 12-10-2021, 06:45 AM
  #47
smartshah's Avatar
can you please set the language to English and then screenshot the error.
Old 12-10-2021, 06:59 AM
  #48
Seba9009's Avatar
My Ride: E60
the right side seems to work anyway because I can control it at ista. left side throws a communication error.
Old 12-10-2021, 07:07 AM
  #49
smartshah's Avatar
Seems like you have not followed all the instructions properly. There is one cable from each side that need to be disconnected, or removed. Just unplug them at the LM. And unpin them, tape them up. There is one cable each, from both lights that need to be grounded. Please read through the above and do as it states, make sure you are unplugging and plugging in the correct cables.
The AHL Fault should not be there. As you should code it out.
Old 12-10-2021, 07:15 AM
  #50
smartshah's Avatar
Check this URL for all the PIN assignments
https://5series.net/forums/e60-e61-parts-accessories-mods-22/pre-lci-bi-xenon-pre-lci-adaptive-bi-xenon-retrofit-help-147257/page3/
Quick Reply: AHL unit removal for pre 03/2005 with adaptive headlights for LM1 to LM2 changes
