AHL unit removal for pre 03/2005 with adaptive headlights for LM1 to LM2 changes
Old 12-10-2021, 02:31 AM
  #31
Seba9009's Avatar
My Ride: E60
Originally Posted by smartshah
Hi there,
Can you please list the steps on what you did, or what you are trying to achieve?
Are you trying to retrofit xenon headlights or adaptive headlights? What was the stock setup of the car you are working on?
car for e61 from ahl. I replaced lm1 in lm2 to get more encoding options. I used this diagram to connect as in the picture. I want lm2 to be compatible with torsion xenons
Old 12-10-2021, 02:51 AM
  #32
smartshah's Avatar
My Ride: 535d M Sport
Torsion?
OK first of all. You don't have an AHL unit. You did not have adaptive Xenon, prior to this install?
You did have xenon? And are retrofitting adaptive xenon?
You need to code out AHL unit from the LM2. Can you please send me a pic of the LM2 module, with the sticker.
Old 12-10-2021, 03:01 AM
  #33
Seba9009's Avatar
My Ride: E60
Torsion?
i use translator because my english is not good. I have Xenon Dynamic. Vin B489604. LM2 9 153 273.
Old 12-10-2021, 03:08 AM
  #34
smartshah's Avatar
You must code out AHL from the LCM2. As you do not have AHL Unit installed.
Old 12-10-2021, 03:13 AM
  #35
Seba9009's Avatar
My Ride: E60
after replacing the LM2, I did the coding, I entered Vin. changed the date to # 0305, did cas and lm encoding. Ista cannot see the AHL module.
Old 12-10-2021, 03:15 AM
  #36
smartshah's Avatar
You need to code out the AHL unit from the LM2. If you open up NCS Dummy, and search AHL. You will have option installed and not Installed. Click Not installed.
You should not see AHL unit under the control unit tree list
Old 12-10-2021, 03:20 AM
  #37
Seba9009's Avatar
My Ride: E60
do you remember what this option to disable? I have already searched and found only ALC_Verbaut but that's not it.
Old 12-10-2021, 03:21 AM
  #38
smartshah's Avatar
Do you not have NCS Dummy installed?
Old 12-10-2021, 03:22 AM
  #39
smartshah's Avatar
it will aktiv or non aktiv. But it is AHL Unit.
Old 12-10-2021, 03:23 AM
  #40
Seba9009's Avatar
My Ride: E60
I have.
Quick Reply: AHL unit removal for pre 03/2005 with adaptive headlights for LM1 to LM2 changes
