Adding speed camera POI to your SatNav DVD
Old 05-20-2006, 11:16 AM
  #21
aybeesea's Avatar
Well I obviously have nothing better to do than choose totally stupid POIs to add to the system.
Just added UK Supermarkets to Pub. places, businesses, shops and UK Fast Food outlets (of all things(!!)) to Hotels and restaurants.
Nothing like lowering the tone!!
ABC
Old 05-20-2006, 01:19 PM
  #22
BangleBox_530d's Avatar
My Ride: E60 530d Sport - Carbon Black, Black Dakota Leather, Media Pack (satnav, bluetooth, CD changer), heated font seats, through load
Sadly, I'm interested. Where do you get the POIs from?
Old 05-20-2006, 01:26 PM
  #23
aybeesea's Avatar
You can register for free on POI Place where you can get them in OV2 format then you have to convert them to ASC, merge the different ASCs into the two main categories, sort them into longitude order and run the PERL script to generate the IDX and URL files OR you could PM me with your email address and I could send you the two merged and sorted ASC files (and the URL and IDX files if you wish...).
ABC
Aren't you watching the scoring on the Eurovision? :'(
Old 05-20-2006, 02:21 PM
  #24
General's Avatar
Originally Posted by mathmos' post='285226' date='May 20 2006, 01:55 PM
You have the 2006-02 NAV DVD. There are a couple of new sections in the eng.lsc file that also need updating in addition to the ones mentioned previously however they are easy to spot. It's just a case of working your way through each of the new sections and copying then renaming as required.
If you really get stuck just shout and I'll show you what I mean.
Mathmos - I'm working my way through your brilliant instructions but your comment above has thrown me a bit - which additional sections within the eng.lsc file need updating? Your further help would be much appreciated.
Old 05-20-2006, 02:52 PM
  #25
I presume it means to add a line for "9000" everywhere you see 9101.
SA 7395 10002 10008
SA 9101 10003 10008
Should that become
SA 7395 10002 10008
SA 9000 10003 10008
SA 9101 10003 10008
I'm not sure what the last numbers refer to exactly.
Old 05-20-2006, 03:30 PM
  #26
General's Avatar
SA 7395 10002 10008
SA 9101 10003 10008
Should that become
SA 7395 10002 10008
SA 9000 10003 10008
SA 9101 10003 10008
Thanks Banglebox - Also not sure what the second sets of figs are meant to be - at first glance they appear to refer to the TPD-GRP entries earlier in the file (?)
On closer inspection of the file I think there are a few other places to add the 9000 entries to, eg.
1. the section beginning with IA (below the SA lines) and
2. the section beginning with TPD-SEV (where the .idx and .url files creared earlier are referenced) toward the end of the file.
Will give it a try and see what happens.
Old 05-20-2006, 08:27 PM
  #27
aybeesea's Avatar
The second sets of figures refer to the Searchable Attribute ID [SADESC]. I believe this determines the visibility of the icons at different zoom levels.
With mathmos' help, the suggested vallues for SpeedCams is:
Code:
SA	9000	10004 10008
I have made Supermarkets same as Shopping Centres:
Code:
SA	  9003	10003 10008
and Fast Food same as Restaurants:
Code:
SA	  9004	10002 10008
Have fun.
ABC
Old 05-20-2006, 11:02 PM
  #28
aybeesea's Avatar
Couldn't resist adding Chippies.
Some other good POIs here.
ABC
Old 05-23-2006, 03:23 AM
  #29
amjad175's Avatar
Mathmos,
Thanks very much for the detailed instructions.
After a couple of false starts, I have a 'working' DVD, first 2 attempts used CR+LF in VEdit and I think that stopped them from working.
Although the DVD now works, it throws up DVD Read Errors randomly, probably due to very old blank DVDs I had. I am about to buy new media and just wondered if you had come across good/bad brands in your experiments!
Does the E60 read DVD+R or just DVD-R? Which produced better results?
Cheers.
Old 05-23-2006, 04:19 AM
  #30
aybeesea's Avatar
Cheers.
Reads both...
ABC
Quick Reply: Adding speed camera POI to your SatNav DVD
